[Addon] RuneUI Enhancement
Postby AndyF » 22 Jan 2019, 20:36
Hi R101,
I have one bug found: Scrolling starts on long text - but it don't stop on following short text until page is reloaded. I have to learn more Javascript ;)
Andy
AndyF
Postby R101 » 22 Jan 2019, 21:20
AndyF,
Yes, it works sometimes now. (I turned off Dev mode and cleared the cache this time, as well as rebooting.)
I agree that the scrolling behavior depends on the state of the previous display. If the previous display was static, it keeps this state until the display is refreshed. If the previous display was scrolling, it will scroll the new display at a speed depending on the previous display string length, even if it does not need to scroll.
Postby rern » 23 Jan 2019, 10:19
- Fix missing embedded cover arts bug
- Fix Playback text scrolling bug
- Fix Replace+Play sometimes switched to Playback with empty item
Postby AndyF » 23 Jan 2019, 19:36
Hi rern,
thanks for your update! Your fixes works - RuneUIe gets better and better!
Perhaps - can you merge some of my simple fixes to your code? So it would be less work for me to patch after your update ... But of course it 's your project and your decision.
Thank you anyway in advance,
Andy
AndyF
Postby R101 » 23 Jan 2019, 21:02
Hi rern,
Sorry to report that I have lost the metadata scrolling on webradio after this update.
Postby AndyF » 23 Jan 2019, 21:12
Hi R101,
no problem here. Cache?
Regards, Andy
AndyF
Postby R101 » 23 Jan 2019, 21:39
I can get it to scroll by repeating the replace and play selection. If I just change stations without doing it twice, it retains the previous scrolling state.
By the way rern, updating retains the library item settings except for the context menu icon.
Postby rern » 24 Jan 2019, 06:24
Postby AndyF » 24 Jan 2019, 06:56
AndyF
Postby Toube » 24 Jan 2019, 07:22
Hi Rern,
Thanks for the update.
I shall have try on the latest version.
Last version I tested I had problems with .cue files etc not being added to playlist etc.
I'll keep you posted.
-Toube
Toube
