[Addon] RuneUI Enhancement
Postby Toube » 24 Jan 2019, 07:36
So far so good.
I agree with Andy on having the back arrow on the left side at least when using a bigger screen it's easier to navigate. On small screen probably not so much difference.
Navigation now works and I can access the Library as with last version I couldn't.
Questions:
.cue files are opening playlists automatically I assume?
some folders are not opening.. just the logo loading showing.. with normal UI they work?
-Toube
Toube
Postby R101 » 24 Jan 2019, 11:42
Postby AndyF » 26 Jan 2019, 08:09
AndyF
Postby R101 » 26 Jan 2019, 12:58
Hi AndyF,
I have pasted your code in, (monkey see, monkey do - I have no idea how it works) but it does not affect the scrolling info problem I have.
Postby AndyF » 26 Jan 2019, 16:11
Hi R101,
my code don´t do anything with scrolling info - the only use is to refresh top playback buttons in library-tab on add/play a webradio-station. First "dirty hack" sometimes did a double refresh.
I looked into the code - scroll-mode don´t change if you resize your window or rotate your tablet. Sometimes it takes a long time until first infos are displayed. But at the moment I don´t know why.
Edit: It seems, Chrome on Android reloads the page if you rotate your tablet. So scrollmode changes on my system without problems.
regards, Andy
AndyF
Postby R101 » 28 Jan 2019, 17:09
Hi rern,
Info scrolling works for me on a local 7" Pi touchscreen, and on a laptop, but not on a 7" tablet.
Update 20190206
Postby rern » 06 Feb 2019, 13:12
Update 20190206
Fix Playback text scrolling on some devices
Fix text scrolling delay
Fix metadata refresh on add/replace + play
Fix search box display
Improve Playlist elapsed time display
Add tap swipe bar > drop down menu
Disable AAC/ALAC support for faster Library update(re-enable in MPD > FFmpeg setting)
Re: Update 20190206
Postby Toube » 06 Feb 2019, 13:16
Toube
Postby AndyF » 07 Feb 2019, 19:16
Hi rern,
thanks for your update. It works fine so far.
One issue exists on Sources/NFS-mount: The "Advanced mount options" button has no effect. Original 0.5b-version works as expected.
EDIT: Problem is only on existing NFS-mounts. If you create a new mount, all work as expected. So no big problem.
Some GUI related things - Automatic swipe to playback-tab on add/replace-play should be optional. I don't like this on songs (because I'm a zapper), but for webradio it's cool. MP3s with some missing tags produce mixed metadata with previous song.
Regards, Andy
AndyF
Postby s.k. » 07 Feb 2019, 19:17
There is an initial delay when you first open the RuneUIe20190206, from explorer and from the android app.
Is that normal ?
Stavros
(It isn’t a communication problem because the /dev page opens instantly)
s.k.
