[Addon] RuneUI Enhancement
Postby rern » 11 Feb 2019, 14:15
Postby R101 » 11 Feb 2019, 14:37
Hi rern,
I had already tried the webradio import addon, and it did not work. I tried it again after deleting the entry and rebooting, and it worked. Thanks.
MPD rescan makes no difference to the mpc result, even if ffmpeg is disabled.
Postby rern » 11 Feb 2019, 17:07
Postby R101 » 11 Feb 2019, 18:17
Hi rern,
Sorry, but I am not sure what your reply means.
I used your MPD upgrade addon to update 0.4b to v0.20.11, and this got the m3u8 feeds working. I have stayed on Rune 0.4b because these feeds still do not work with v0.5, which has a later version of MPD.
It seems likely that the 0.5 problem is with the way MPD uses ffmpeg rather than MPD itself, so I would be happy to upgrade 0.4b to 0.21.4 if you can tell me how, or can re-enable the addon.
Postby rern » 13 Feb 2019, 04:37
Postby R101 » 13 Feb 2019, 11:41
Postby rern » 13 Feb 2019, 12:53
@R101,
I've relayed this MPD thing to .
Postby rern » 14 Feb 2019, 00:52
Update 20190213
Fix bug - add/replace from Album, Artist, Composer and Genre
Fix missing Back button
Fix Rescan button bug
Improve scrolling texts and scroll at the same speed, 80px/s
Postby AndyF » 14 Feb 2019, 06:49
Hi rern,
I´ve found another CoverArt-related issue - if you switch from playlist (after select a different track from there) to playback-tab, CoverArt is not up to date. Metadata are correct, but CoverArt seems not to be refreshed.
regards, Andy
AndyF
Postby rern » 14 Feb 2019, 11:11
