[Addon] RuneUI Enhancement
Postby rern » 06 Mar 2019, 15:22
Postby AndyF » 06 Mar 2019, 20:40
Hi rern,
thanks for your effort! This version is a really fine one.
One thing: If mp3-title is not tagged, library don' t show a bold song name - If I remember correctly, in older versions filename was shown instead.
Bug or changed behaviour?
Regards, Andy
AndyF
Postby Garrido33 » 08 Mar 2019, 10:37
Hi Rern,
Thanks for your work !
On my official 7" touchscreen with v 0.4b, the "Screen Off" option doesn’t work correctly (there is still an active light on the screen) and the UI isn't reactivated when you tap on the screen. Without RuneUI Enhancement, it works perfectly.
Regards,
Garrido33
Garrido33
Postby AndyF » 09 Mar 2019, 13:16
Hi rern,
some new (old?) issues with latest version:
- m3u.-files don´t work correct. You can dive in - but adding some songs to playlist has no effect.
- if a m3u-file is in a folder, CoverArt in library don´t work there
- navigation in CoverArt-Browsing is not correct on albums with "dummy"-CoverArt. Steps to reproduce:
1. Start CoverArt-browsing
2. browse to an album with dummy-CoverArt
3. go back with back-button
4. go back a second time with back-button -> target is albumlist instead of main-library.
regards, Andy
AndyF
Postby klassikmann » 10 Mar 2019, 22:45
@rern
After today's update the menu item "Playback Items" results in a pop-up window () without any function. Same is true for "Library Items".
Additionally, a feature request:
Most of the contents of my RuneAudio server is classical music. I don't arrange the music according disks but according composers and their works. If the contents of e.g. a CD is music from different composers, then the different works will be stored at different leaves of my music tree, but with the same CD cover. As a consequence, the new searching by CoverArt, although very impressive in general, is of a very reduced significance in my environment because it does not securely point to the envisaged work. Therefore I kindly ask to make the CoverArt tile in the library menu configurable.
klassikmann
Postby klassikmann » 11 Mar 2019, 13:07
klassikmann
Postby rern » 11 Mar 2019, 13:12
Postby rern » 11 Mar 2019, 13:26
Postby klassikmann » 11 Mar 2019, 15:38
klassikmann
Postby Garrido33 » 11 Mar 2019, 23:23
Hi Rern,
The "Screen off" function now works perfectly on my 7" touch screen with Rune 0.4. I think it's better to leave the manual button "Screen off" in case you only want to occasionally turn off the screen or you want a longer time (I saw someone here who wanted the screen to be turned off after two hours).
Some issues :
- Webradios no longer work
- When you want to save a playlist and name it, there is no longer a keyboard on the local touch screen (you must do it remotely)
- When loading a playlist, only the icons are displayed (no title), and they are inactive.
Regards,
Garrido33
Garrido33
