[Addon] RuneUI Enhancement
Postby klassikmann » 12 Mar 2019, 08:18
klassikmann
Postby rern » 12 Mar 2019, 10:02
Postby klassikmann » 12 Mar 2019, 10:18
klassikmann
Postby klassikmann » 12 Mar 2019, 13:22
The sorting of tracks in the library view is no more according track numbers but "at random".
Look here: https://www.magentacloud.de/lnk/9fBJqqLy
The sorting in the playlist view is o.k.
klassikmann
Postby cmh714 » 12 Mar 2019, 16:30
Adding a web radio to the queue fails, but the radios I had in the queue prior to updating are still there and play correctly.
I do NOT use any FFMPEG since that screws up the db update, and have never had any issues with web radios. Having said that, I dont know if the stations I play, use that format.....GDRadio still plays, as does the Zappa station, etc.
Postby rern » 13 Mar 2019, 04:15
Hi guys,
Thanks for reportings.
There're always some bugs slip from the daredevils, pre-release update testers, and me. So bugs reports, feature requests or suggestions are welcome.
Bugs: Fixed. To be released with next update real soon.
- Adding Webradio failed
- Sorting tracks wrong
FFmpeg - So it's still good to have the option to disable during installation.
Postby rern » 13 Mar 2019, 11:41
Update 20190313
- Fix add webradio bug
- Fix track sorting in Library
- Remove context menu icon - use main icon instead
Postby Garrido33 » 13 Mar 2019, 21:50
Hi Rern,
With my v 0.4, I have the following issues :
- There are no more CoverArt images in the "Browse by Coverart" library, but when you click on an empty CovertArt, the album open and the CovertArt is displayed with the songs ;
- The "Single tap song" (Add + Play) no longer works (checked in the library tools), and there is no context menu (impossible to select and add a song to the playlist, impossible to play the song)
- Webradios still don’t work.
Today's Rune UI Enhancement proposed an installation and not an update. The installation lasted very long. I did a reset and reinstalled the addons, but the above mentioned problems have not changed.
Garrido33
Postby cmh714 » 13 Mar 2019, 22:04
@rern, the Webradios work as expected in the latest update on .5
just posting based on the last post above....
Postby Garrido33 » 13 Mar 2019, 22:56
Hi cmh714,
Hi Rern,
You are right : webradios also work in v 0.4, via main icons. I was confused because the Single Tap function doesn't work.
Rern, please ignore my remark about webradios. Thanks.
Garrido33
