[Addon] RuneUI Enhancement
Postby klassikmann » 04 May 2019, 09:52
klassikmann
Postby dynobot » 04 May 2019, 22:07
dynobot
Postby AndyF » 05 May 2019, 09:54
AndyF
Postby rern » 08 May 2019, 05:40
Postby klassikmann » 08 May 2019, 08:15
Issue in Update 20190428
It seems that "Update database" in the Library View doesn't work. OTOH "Update thumbnails" with "Update Library database" ticked shows the desired function.
klassikmann
klassikmann
Postby rern » 10 May 2019, 15:24
- New feature - Metadata Tag Editor
- Install RuneUIe Metadata Tag Editor addon (10+ minutes)
- Library > album view > album/song context menu > Tags
- Fix bugs
- Add single track from Browse By CoverArt
- Partial create/update thumbnails with single quotes in directory name
- Delete dummy thumbnails for albums with *.cue or *.m3u
Postby dynobot » 11 May 2019, 16:23
dynobot
Postby dynobot » 12 May 2019, 16:49
dynobot
Postby R101 » 12 May 2019, 19:32
Hi dynobot,
Just a couple of suggestions, as I only have a Pi3B.
Have you disabled the Bluetooth, which can sometimes interfere with wifi, and are you using a dual-band router with both bands having the same SSID? It might be that after reboot the Pi looks for the 5GHz channel first, and has a problem with it.
Postby dynobot » 12 May 2019, 21:03
dynobot
