[Addon] RuneUI Enhancement
Postby rern » 13 May 2019, 07:48
Update 20190513
- NewFeature - Save coverart button - Directly save coverarts fetched from online
- Fix bug - Names contain certain words, Connected/Escape/OK/Connection/Date, disappear from Playback page
- Correct orientation of coverarts taken directly with phone camera
- Convert webradios data directly from file - no import needed anymore
Postby R101 » 13 May 2019, 10:29
Postby rern » 13 May 2019, 10:30
Postby dynobot » 13 May 2019, 15:14
dynobot
Postby R101 » 13 May 2019, 17:07
Hi dynobot,
I installed 0.5 on a Pi2, did a gitpull, set the time and wifi setup (DHCP), blacklisted the drivers which stop the Edimax wifi dongle working, and rebooted. All OK. I also deleted the dummy test file in netctl.
I have a Pi touchscreen on this, so I made a few changes to the setup and rebooted again. Reconnected OK.
I then installed Addons from the dev page, and rebooted OK.
I expanded the SD card and then installed UIe. I lost a few settings and there seem to be several other problems, but wifi reconnected OK.
Postby dynobot » 13 May 2019, 19:32
dynobot
Postby dynobot » 13 May 2019, 19:42
dynobot
Postby R101 » 13 May 2019, 21:25
Postby dynobot » 13 May 2019, 22:28
@R101
Thank you thats all I needed to know. So for some reason, I am having persistent issues on my end.
Nope I didn't do anything special.
Wrote image to card
Boot up image w/Initial connection via Ethernet
Use GUI to Connect to wifi
Install Addons
Install UI Enhancement
Reboot and unplug Ethernet
System boots with no wifi
Connect Ethernet works
Wifi will not work or connect
Done.
Thank you again for your time and trying this out.
dynobot
Postby klassikmann » 14 May 2019, 08:27
klassikmann
