[Addon] RuneUI Enhancement
Postby R101 » 14 May 2019, 09:57
Postby dynobot » 14 May 2019, 14:44
dynobot
Postby rern » 17 May 2019, 14:07
Postby klassikmann » 17 May 2019, 16:18
klassikmann
Postby rern » 24 May 2019, 07:03
Postby rern » 25 May 2019, 02:59
Postby R101 » 25 May 2019, 09:34
Hi rern,
This update leaves most of the icons as just a font code in my 0.4b.
There is no metadata editing option in the menus. Is this because I do not display any cover art?
Edit:
I also cannot update webradio entries, and the power/reboot function does not work. Seems to be the same with 0.5
Postby AndyF » 25 May 2019, 10:13
Hi rern,
thanks for your work!
There are small issues in latest update:
- playlist-tab needs a refresh if you remove all items via "-"-button.
- some online-found-cover are displayed as empty rectangle (of course it could be a provider-problem, too).
regards, Andy
AndyF
Postby rern » 25 May 2019, 11:23
Postby AndyF » 25 May 2019, 12:04
Hi rern,
thanks for your fast reply! Update branch clears my playlist properly.
Another small glitch: Context-menu "Add" / "Add+Play" at library removes blue color of library-tab at bottom.
And install-script throws an error of missing "setown"-command. (No side effects so far).
Regards, Andy
AndyF
Users browsing this forum: No registered users and 44 guests
