[Addon] RuneUI Enhancement
Postby R101 » 25 May 2019, 20:47
"Star" Image Issue
Postby rern » 26 May 2019, 09:10
"Star" Image Issue
It's turned out to be serious and permanent, according to .
Coverarts and images in Bio which use Last.fm as online source won't work anymore. I'm looking into getting them from somewhere else.
Postby klassikmann » 26 May 2019, 10:04
klassikmann
Postby rern » 26 May 2019, 16:21
Re: "Star" Image Issue
Postby dynobot » 26 May 2019, 17:28
never mind
dynobot
Postby rern » 29 May 2019, 05:17
Postby dynobot » 30 May 2019, 00:33
dynobot
Postby dynobot » 30 May 2019, 00:55
Party over
Tried another ....no wifi, this command returned nothing
redis-cli get wlans | tr -d '\\"' | sed 's/,/\n/g' | grep ESSID
root@classicrunehavana(rw):~# redis-cli get wlans | tr -d '\\"' | sed 's/,/\n/g' | grep ESSID
root@classicrunehavana(rw):~# redis-cli get stored_profiles | tr -d '\\"[]' | sed 's/,/\n/g'
test
XXXXX<-----my saved network shows up...the one that worked before the reboot
It always turns my wifi off and can not be turned back on
Digging deeper.....rfkill list showed wlan0 was being soft blacked, I used rfkill unblock 0 to unblock it....after that wifi was back on BUT when I try to save the connection it will not save
Summary
Problem #1 - soft blocking wlan0
Problem #2 - not allowing new wifi connections to be saved
dynobot
Postby dynobot » 30 May 2019, 02:28
More info
journalctl -xe
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activating via systemd: service name='org.freedesk>
May 29 14:19:06 classicrunehavana dbus-daemon[257]: [system] Activation via systemd failed for unit 'dbus-org.f>
May 29 14:19:06 classicrunehavana sshd[3243]: pam_systemd(sshd:session): Failed to create session: Unit systemd>
May 29 14:19:12 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:09 classicrunehavana kernel: Under-voltage detected! (0x00050005)
May 29 14:23:13 classicrunehavana kernel: Voltage normalised (0x00000000)
May 29 14:23:15 classicrunehavana sudo[3552]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/srv>
May 29 14:23:15 classicrunehavana sudo[3552]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3552]: pam_unix(sudo:session): session closed for user root
May 29 14:23:17 classicrunehavana sudo[3579]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=/usr>
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:17 classicrunehavana sudo[3579]: pam_unix(sudo:session): session closed for user root
May 29 14:23:27 classicrunehavana sudo[3619]: http : TTY=unknown ; PWD=/srv/http ; USER=root ; COMMAND=./se>
May 29 14:23:27 classicrunehavana sudo[3619]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 29 14:23:27 classicrunehavana systemd[1]: Reloading.
May 29 14:23:28 classicrunehavana systemd[1]: Starting Automatic wireless network connection using netctl profi>
-- Subject: Unit netctl-auto@wlan0.service has begun start-up
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/l ... temd-devel
-- Unit netctl-auto@wlan0.service has begun starting up.
May 29 14:23:28 classicrunehavana kernel: Under-voltage detected! (0x00050005)
May 29 14:23:28 classicrunehavana netctl-auto[3649]: The interface 'wlan0' is already up
May 29 14:23:28 classicrunehavana systemd[1]: netctl-auto@wlan0.service: Control process exited, code=exited st>
May 29 14:23:28 classicrunehavana systemd[1]: netctl-auto@wlan0.service: Failed with result 'exit-code'.
May 29 14:23:28 classicrunehavana systemd[1]: Failed to start Automatic wireless network connection using netct>
-- Subject: Unit netctl-auto@wlan0.service has failed
-- Unit netctl-auto@wlan0.service has failed.
-- The result is RESULT.
May 29 14:23:28 classicrunehavana sudo[3619]: pam_unix(sudo:session): session closed for user root
May 29 14:23:34 classicrunehavana kernel: Voltage normalised (0x00000000)
lines 1205-1239/1239 (END)
dynobot
Postby dynobot » 30 May 2019, 02:44
fixed the under power issue now this
journalctl -xe
May 29 14:38:14 classicrunehavana devmon[682]: opticaldisc: []
May 29 14:38:14 classicrunehavana devmon[682]: numaudiotracks: []
May 29 14:38:14 classicrunehavana devmon[682]: blank: []
May 29 14:38:14 classicrunehavana devmon[682]: media: []
May 29 14:38:14 classicrunehavana devmon[682]: partition: [1]
May 29 14:38:14 classicrunehavana devmon[682]: ===========================================
May 29 14:38:14 classicrunehavana devmon[682]: changed: /org/freedesktop/UDisks/devices/mmcblk0p1
May 29 14:38:14 classicrunehavana devmon[682]: device: [/dev/mmcblk0p1]
May 29 14:38:14 classicrunehavana devmon[682]: systeminternal: [0]
May 29 14:38:14 classicrunehavana devmon[682]: usage: [filesystem]
May 29 14:38:14 classicrunehavana devmon[682]: type: [vfat]
May 29 14:38:14 classicrunehavana devmon[682]: label: []
May 29 14:38:14 classicrunehavana devmon[682]: ismounted: [1]
May 29 14:38:14 classicrunehavana devmon[682]: nopolicy: [0]
May 29 14:38:14 classicrunehavana devmon[682]: hasmedia: [1]
May 29 14:40:03 classicrunehavana systemd-timesyncd[237]: Synchronized to time server 45.76.244.202:123 (pool.n>
May 29 14:40:03 classicrunehavana systemd[1]: Reloading.
May 29 14:40:03 classicrunehavana hostapd[285]: wlan0: INTERFACE-ENABLED
May 29 14:40:03 classicrunehavana avahi-daemon[251]: Joining mDNS multicast group on interface wlan0.IPv4 with >
May 29 14:40:03 classicrunehavana hostapd[285]: Failed to set beacon parameters
May 29 14:40:03 classicrunehavana avahi-daemon[251]: New relevant interface wlan0.IPv4 for mDNS.
May 29 14:40:03 classicrunehavana avahi-daemon[251]: Registering new address record for 192.168.5.1 on wlan0.IP>
May 29 14:40:03 classicrunehavana kernel: brcmfmac: power management disabled
May 29 14:40:18 classicrunehavana sshd[1758]: Accepted password for root from 10.10.12.86 port 52856 ssh2
May 29 14:40:18 classicrunehavana sshd[1758]: pam_unix(sshd:session): session opened for user root by (uid=0)
May 29 14:40:18 classicrunehavana dbus-daemon[244]: [system] Activating via systemd: service name='org.freedesk>
May 29 14:40:18 classicrunehavana dbus-daemon[244]: [system] Activation via systemd failed for unit 'dbus-org.f>
May 29 14:40:18 classicrunehavana sshd[1758]: pam_systemd(sshd:session): Failed to create session: Unit systemd>
May 29 14:40:34 classicrunehavana systemd-udevd[209]: Process '/var/www/command/refresh_ao' failed with exit co>
dynobot
