[Addon] RuneUI Enhancement
Postby dynobot » 30 May 2019, 03:11
went to /etc/netctl
removed test
via the UI no saved interfaces show up
went back to the netctl dir and removed my network ssid
went back to the UI and found then entered my ssid info to connect....varified this in the netctl dir as it showed up
reboot...nothing no wifi connection
went back to the netctl dir and I can see my network info ssid....however via the UI no saved networks
However this command results in an empty list...redis-cli get stored_profiles | tr -d '\\"[]' | sed 's/,/\n/g'
So even though its stored in the netctl dir its not getting over to the redis-cli.....I GUess
dynobot
Postby dynobot » 30 May 2019, 04:58
Finally got it to work.
dynobot
Postby rern » 30 May 2019, 05:26
Postby dynobot » 30 May 2019, 13:34
Hi Rern
I just want to confirm that you are saying YES you were able to reproduce the problem of losing your wifi connection after installing the UI Enhancement?
dynobot
Postby rern » 30 May 2019, 13:59
Postby dynobot » 30 May 2019, 15:06
Your method is not a replication of the issue and actually will not solve the issue.
As stated in my previous posts 'after' RuneUI Enhancement is installed the ability to connect to wifi is lost. It does not matter how many times you reboot, try to scan, remove test files etc.
I identified a soft block of wlan0, this alone will make it impossible to connect to wifi. This was resolved by rfkill unblock 0
Method
-flashing a new image
-boot up
-removed the test file located in /etc/netctl
-connect to wifi network
-install Addons
confirm that wifi is not blocked - rfkill list, if it is unblock with rfkill unblock 0
-confirm wifi is still able to scan - redis-cli get wlans | tr -d '\\"' | sed 's/,/\n/g' | grep ESSID
-confirm new connection is in netctl - redis-cli get stored_profiles | tr -d '\\"[]' | sed 's/,/\n/g'
-confirm redis-cli save command is in file - cat /srv/http/enhance.php | grep 'redis-cli save'
-run netctl - netctl-auto switch-to ESSID
-run redis-cli save - system says OK
-reboot
After
-confirm wifi working rfkill list - OK working
-confirm network connection saved in netctl dir + redis-cli get stored_profiles | tr -d '\\"[]' | sed 's/,/\n/g' - OK saved
-check UI to verify network connected - NO not connected
-check ifconfig - NO wlan0 ***strange because via the UI I can scan and see networks****
Although wifi is working, the connection is saved in redis-cli the default 192.168.xxx.xxx persists = wifi connection not working
dynobot
Postby dynobot » 30 May 2019, 16:00
Further investigation
ifconfig - no wlan0 showing
systemctl - wpa_supplicant@wlan0.service loaded failed failed
systemctl - netctl@my_network.service loaded failed failed
dynobot
Postby ga1580 » 30 May 2019, 16:46
I was experiencing some slow load time on the old interface, and updated to the UI Enhancement today. Pretty slick, and was working much quicker for a couple hours.
Now when I go to load the app on my phone or using browser on my pc, it just sits on the logo screen. Tried powering down and restarting, same issue. It isn't a delay, been sitting on the logo for 10 minutes. I know the system is up because I can still cast music to the Rune and it is working through the speakers, but I can't access any controls. Any idea what would have changed that quickly?
ga1580
Postby rern » 30 May 2019, 17:03
@dynobot,
- I have posted what commands that could help me to get to the issue which you ignored.
- Then you're back with a couple posts full of logs.
- I took a wild guess to reproduce the issue and asked you to add your finding if there're any differences.
- You wanted my confirmation that I've reproduced it in spite of the detail of every steps.
- Then you threw it back at me that it's not the case and not the solution. Obviously, it's not which you can tell from my post in the first place. How could it be?
- Your solution, that's good for you and someone with the same issue.
- I've asked and still don't know after which one, Addons or RuneUI Enhancement, that caused the issue.
I think you should contact me via private message instead. This is too long for this thread.
Postby dynobot » 30 May 2019, 17:09
dynobot
