[Addon] RuneUI Enhancement
Postby vennesch » 21 Jun 2019, 16:35
vennesch
Postby rern » 22 Jun 2019, 04:37
Postby ceejayemm » 22 Jun 2019, 11:32
I had to reflash Rune this morning so used the 0.5b original image (20180903_runeaudio_rpiB2.img.gz) and then used gitpull to update to the latest release (v11).
Connected to my NAS based music library via NFS and updated database - all OK.
Updated to the latest RuneUIe (20190622) and completed my nornal set up, again all OK.
With this done I then went to add my web radio setup back to the library. I entered the name and URL of radio stations I have used (many provided via Minimserver, but not all) and none of them were saved to the library. I rebooted my device and tried again, same result.
What might be causing my radio setting not to be saved ?
Many thanks for any help with this issue.
Chris
ceejayemm
Postby rern » 22 Jun 2019, 12:10
Hi Chris,
It's a bug. A fix will be released with next update soon.
By the way, anything to share about the new Color feature?
Postby klassikmann » 22 Jun 2019, 12:49
klassikmann
Postby AndyF » 22 Jun 2019, 18:05
I agree - color feature works like a charm. So RuneUIe can be customized a lot.
A big thanks to rern!
Andy
AndyF
Postby rern » 23 Jun 2019, 14:17
Update 20190623
- Fix add webradio bug
- Fix playlists conversion during install
- Fix playlists with 1,000+ tracks not show
- Fix saved playlists with 1,000+ tracks not load
- Fix missing sampling info on add/replace + play
- Reinstate Last.fm as primary source for online coverarts (coverartarchive.org as secondary)
Postby ceejayemm » 23 Jun 2019, 18:38
Rern
Thanks for fixing the web radio bug, all seems OK again now.
As to the new colour changing options, I had a quick look but to be honest its not something I would use that often (or at all) but it seems to work as noted.
Thanks for the quick response.
Chris
ceejayemm
Postby Ripa » 30 Jun 2019, 15:14
Hi Rern,
is there a way to add only runeUI without the the othe add on.
It seems that if i add it by /dev it does not work it won't start up
thanks
Ripa
Postby rern » 30 Jun 2019, 16:02
