[Addon] RuneUI Enhancement
Postby R101 » 28 Nov 2017, 19:25
Sorry rern, but I am not clear about the situation.
My version (20171128) of addons menu works perfectly well so long as I do not update the enhancements addon. Should I now be able to update enhancements without problems, or is the spinner problem due to something which is not corrected by the automatic addons update?
Addons was updated when I clicked the menu today so I tried updating the enhancements. This resulted in the spinning symbols again, so I reverted to the previous working image. I am not sure whether you are saying the uninstall/reinstall of addons is needed even if if Rune is working, or just for those stuck with a non-working installation.
Postby rern » 29 Nov 2017, 03:24
@s.k. & @R101,
I've just tried:
- virgin RuneAudio 0.4b on RPi 3
- SSH > install Addons Menu
- Addons Menu > install RuneUI Enhancement >> OK
- Addons Menu > uninstall & reinstall RuneUI Enhancement multiple times >> OK
- SSH uninstall > reinstall Addons Menu multiple times >> OK
The issue was narrowed down to 3 files which recent updates left some lines behind:
header.php - top-bottom bar
playback.php - main content
footer.php - javascript references
Try:
1. clear OPCache
- SSH: systemctl reload php-fpm > refresh browser
2. silver bullet:
- browser URL: < RuneAudio IP >/restoreui.php > the files restored to default
- Menu > Addons > (Addons Menu install) > update installed addons
3. start a virgin RuneAudio
Postby s.k. » 29 Nov 2017, 05:50
ok then,
- virgin RuneAudio 0.4b on RPi 2
- Addons Menu > install RuneUI Enhancement > OK
RuneUI works just fine!
Change Network to Static >reboot> Endless spinning
I don’t know what to say…
s.k.
Postby R101 » 29 Nov 2017, 11:52
Just in case it is significant, I use a fixed IP too.
Postby rern » 01 Dec 2017, 03:07
Postby FauDrei » 02 Dec 2017, 01:10
FauDrei
Postby R101 » 02 Dec 2017, 12:38
Postby hondagx35 » 02 Dec 2017, 13:56
Hi R101,
i did some tests with my image (RuneAudio_rpi2_rp3_0.4-beta_20170229_2GB.img) and all works like it should.
Have you tried different browsers?
Postby R101 » 02 Dec 2017, 14:16
Frank,
I have tried desktop Firefox and an Android tablet. Neither will connect.
Are there any settings which could cause this? I have only the time and top-bottom menu showing on the playback page.
Postby rern » 02 Dec 2017, 14:34
@R101,
Try with local storage (SD card) music files :
- virgin RuneAudio
- copy some music files to /mnt/MPD/LocalStorage
- rebuild library
If default is OK:
- install Addons Menu
- install RuneUI Enhancement
Then try mount network share.
