RuneUI not up or starting
Postby akhali1 » 07 Apr 2020, 18:02
Hi, I have a RasPI 3 (possibly B) and Runeaudio 0.3. Ancient installation, probably 4 years old. All I do is upload/delete songs to it and refresh the library. Currently, I cannot access the RuneUI, but I can ssh into the box. What can I do to verify whether the required processes are running or start them?
akhali1
Re: RuneUI not up or starting
Postby janui » 09 Apr 2020, 10:01
Hi akhali1,
You could try following the instructions here to reinstall the UI from the nightly build: https://www.runeaudio.com/documentation ... /updating/
The nightly build is the current release and has not changed for many years.
Otherwise download the image re-flash the Micro-SD card. You could also then try one of the later versions, like this one: runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html
Postby akhali1 » 10 Apr 2020, 15:08
Hi Janui,
I ran the nightly build commands off the linked page, but status is still the same: I can connect via ssh, but http connection times out. How can I check what the status of the webserver is, or is there a log where I can see how far the start-up sequences got?
akhali1
Postby janui » 11 Apr 2020, 10:27
Users browsing this forum: Bing [Bot] and 5 guests
