RuneUI with Chrome's "Add to Homescreen" feature
Re: RuneUI with Chrome's "Add to Homescreen" feature
Postby Peter » 28 Jul 2014, 10:08
Peter
Postby kajica » 10 Nov 2014, 16:50
create application shortcut is under chrome menu : More tools : Create application shortcut :
cheers!
kajica
Postby mars68 » 08 Dec 2014, 11:13
I played with "add to homescreen" on an ipad / ios8 / safari.
While the RuneUI does show fullscreen, which is great, it doesn't seem to be running very well in this mode.
* The pause/play buttons on the top of the screen appear to be somehow unresponsive, you need to keep them pressed for a few seconds to trigger an action. This could be due to the controls being to close to the area used to swipe down notification panel on IOS.
* The circular volume control randomly doesn't show, only the 3 small square buttons are present.
mars68
Postby ACX » 09 Dec 2014, 00:25
Postby mars68 » 09 Dec 2014, 13:28
mars68
Postby mars68 » 09 Dec 2014, 22:37
mars68
Postby ACX » 10 Dec 2014, 00:53
Postby ACX » 10 Dec 2014, 00:54
Postby mars68 » 10 Dec 2014, 08:45
mars68
Postby mars68 » 10 Dec 2014, 09:51
Actually, a closer look at the screen suggests the size (height) is ok BUT the UI is sort of shifted up: there is some free space below the UI which should actually on the top of the UI. The height of free space below seems to match.
mars68
