Running Rune on RPI3 - but no upnp client option
Postby ttarpd » 17 May 2016, 21:23
I'm new to the world of the Raspberry Pi having just got my RPI3 today.
I want to use it as a UPNP client to play music via a USB port on the RPI3 into my DAC.
I have installed RuneAudio on the RPI3, and also the Android control app.
I have a working UPNP / DLNA music server (Asset running on a QNAP NAS drive) that is working fine.
The RPI3 has a wired connection to my home network.
Before installing RuneAudio I did install Raspbian and the RPI3 can "see" the UPNP server. I installed Kodi on Raspbian and it could play music from the UPNP server fine.
But I wanted to use RuneAudio since the RPI3 will be a dedicated music client feeding my DAC.
However - I can't see anywhere in RuneAudio to configure access to a UPNP server. It only seems to be talking about USB drives or network mounts. Can RuneAudio play music as a UPNP client please?
Regards,
David
ttarpd
Re: Running Rune on RPI3 - but no upnp client option
Postby tboooe » 17 May 2016, 22:13
I use RuneAudio and Pi3 as a renderer on my network getting music served to it from Minimserver.
Under RuneAudio settings have you turned on UPnP/DLNA? Once you do, RuneAudio should be visible on your network.
tboooe
Postby ttarpd » 18 May 2016, 07:54
ttarpd
Postby ttarpd » 18 May 2016, 08:21
ttarpd
Postby hondagx35 » 18 May 2016, 12:01
Postby ttarpd » 18 May 2016, 12:46
ttarpd
Postby hondagx35 » 18 May 2016, 14:00
Postby tboooe » 18 May 2016, 14:07
tboooe
Postby ttarpd » 18 May 2016, 18:43
ttarpd
Postby tboooe » 18 May 2016, 20:27
Glad it worked for you David! With all the acronyms things can definitely get confusing.
So are you considering using the Pi3 with something like a Digi+? I am currently trying to see if my Pi3 and Digi+ acting as a renderer on my network sounds better than my fully tricked out PC.
tboooe
