SATA connection
Cubietruck related support
SATA connection
Postby adosero » 02 Aug 2015, 10:50
Hi everyone,
I've been using a windows server 2012 based CAPS for a while and I wanted to give a try to cubietruck and runeaudio after I heard really good things about this combo.
I followed the guides and everything works like a charm except I can not connect my music storage ssd via sata port. I searched different forums about sata connection and I finally found out that I need to set the things manually.
Could you kindly help me to make it recognise and use my music ssd on rune audio? Please note that I had never seen a linux screen before I purchased this little marvel.. :)
Thanks a lot in advance..
Best.
adosero
Re: SATA connection
Postby hondagx35 » 02 Aug 2015, 12:28
Re: SATA connection
Postby adosero » 02 Aug 2015, 13:27
wow, thank you Frank.
I'm using a mac so I connected thru terminal. It didn't ask the username, asked only the password and rune did not work. do you have any idea why?
thanks again..
Serhan@192.168.0.16's password:
Permission denied, please try again.
adosero
Re: SATA connection
Postby adosero » 02 Aug 2015, 14:33
oups my bad.. I had to login as root@...
adosero
Re: SATA connection
Postby adosero » 02 Aug 2015, 14:42
WHan I type blkid here is what I get:
[root@runeaudio ~]# blkid
/dev/sda1: LABEL="Audio" UUID="94B01BABB01B933A" TYPE="ntfs" PARTUUID="39eea139-01"
/dev/mmcblk0p1: UUID="87d2dfcb-3ec2-4c71-a5d5-0994ab87de7e" TYPE="ext4" PARTUUID="000bd832-01"
/dev/mmcblk0: PTUUID="000bd832" PTTYPE="dos"
how should I edit the the file /etc/fstab afterwards?
thanks a lot again for your help..
adosero
Re: SATA connection
Postby hondagx35 » 02 Aug 2015, 15:12
Re: SATA connection
Postby adosero » 02 Aug 2015, 15:54
thank you very much Frank, everything works like a charm and sound is definitely better!
adosero
Return to Cubietruck
