Schiit MODI DAC
Re: Schiit MODI DAC
Postby DustySeven » 05 Oct 2014, 02:58
worked on RUNE today to prep for helping someone else. Thanks for the code Orion, it work flawlessly
DustySeven
Re: Schiit MODI DAC
Postby silvrr » 14 Oct 2015, 17:19
Thought I would provide an update on the Schiit Modi since I couldn't find a lot of current information on it.
Raspberry Pi 2 (v0.3-beta (14/04/2015)) and a Schiit Modi 2 has provided perfect playback for 16/44 and 24/96 files. No issues getting it all started, no updates or changes needed, it was plug and play. Note that I have my Modi in Standard Mode using the switch on the back.
I will try to get my hands on some higher bit rate content to test compatibility and report back later.
silvrr
Re: Schiit MODI DAC
Postby silvrr » 15 Oct 2015, 02:04
Added some 24/192 files to my pi tonight and while they play they all seem to exhibit a bit of noise/click randomly. It almost sounds like the click/pop from an LP but it doesn't happen consistently so it doesn't seem to be the source file.
I rarely listen to 24/192 stuff so not an issue for me but thought I would report my findings.
silvrr
Re: Schiit MODI DAC
Postby silvrr » 02 Nov 2015, 01:05
silvrr
Re: Schiit MODI DAC
Postby Jim Creek » 03 Aug 2017, 21:54
My Modi Multibit worked instantly, right out of the box, with Rune 03. I have a Pi3. The sound is fabulous. Have all issues with Rune03 and the Multibit been worked out?
Jim Creek
Return to Compatibility list
