Set MPD directory to scan (not whole disk)
Postby xenixesa » 18 Aug 2015, 22:41
I am absolutely loving the RuneAudio. Tried every Kodi-based distribution and Volumio with my RaspberryPi+Schiit Modi without success. RuneAudio works out of the box.
One thing and then it is perfect and you can stop development: I don't want the whole USB hard disk scanned for files, but just a subdirectory.
There is not an option for this and alot of my music is not ready to be in the library yet.
Anybody know of a workaround? I looked at the mpd.conf file but it is obvious that cannot be edited for this purpose.
Cheers and again great work!
xenixesa
Re: Set MPD directory to scan (not whole disk)
Postby hondagx35 » 18 Aug 2015, 23:30
Postby ACX » 19 Aug 2015, 07:25
Or, after the first indexing, you can disable the automatic database update and then manually update the single folders via UI when needed.
Postby xenixesa » 19 Aug 2015, 18:14
Brilliant, both of your solutions. You can stop developing now, Runeaudio is perfect! :)
xenixesa
Users browsing this forum: Baidu [Spider] and 6 guests
