"Setup the Library home screen" Button?
Postby KHatfull » 10 Dec 2014, 16:31
Either it's not implemented or I'm stupid. What does it do and how do you setup the library screen with it?!
I can't find anything in the doco or searching the site with Google.
Thanks.
Synology DS214+ -> RP3 -> Hifiberry Digi+ -> Audio-Gd NOS1704 (coax) -> Audio-GD C-2 preamp/headphone amp ->
1) Yamaha M-4 Power Amp -> Energy Pro 22 Speakers OR 2) HiFiMan HE-400i
Audio Nirvana!!!
KHatfull
Re: "Setup the Library home screen" Button?
Postby ACX » 10 Dec 2014, 17:24
Well, it only works when you have already saved at least one bookmark in your Library home (you can do that from the contextual dropdown menu in the browse by file mode). I'll hide it when no bookmarks are available, or I'll give it a more useful use. Thank you for the feedback!
Postby KHatfull » 10 Dec 2014, 18:23
Ah, I see...from the description "Setup the Library home screen" I assumed it let you hide or unhide the elements of the Library screen. I'd love to hide Spotify, Dirble, and Jamendo as I'll never use them.
Thanks!
Audio Nirvana!!!
KHatfull
Postby ryanmcclure » 10 Dec 2014, 19:10
+1 to hiding things that we don't use. I'm not sure how feasible this is, but I believe that many people would enjoy having that functionality. (Of course, there's a million other awesome things happening with RuneAudio that are WAY more important than this :P )
Ryan McClure
Raspberry Pi Model B + RuneAudio + HifiBerry DAC + Lepai LP-2020A+ + Bose 141 Bookshelf Speakers
ryanmcclure
Postby ACX » 10 Dec 2014, 23:21
Postby Dohmar » 09 Apr 2016, 06:13
Hi guys
I was wondering if there is a solution to this? I too would like to hide Spotify...
Cheers
-D
Dohmar
Postby surfninja » 13 Apr 2016, 15:59
Frank showed us how to re-arrange the screen per someone's request. I can't find it but if one can re-arrange the blocks, one can probably remove one (like the Spotify one).
If someone sends the link, I can take a look at it. I don't use spotify (or drible or ...) either. this might work until the next version that is more configurable.
<50 minutes later>
I found Frank's post is-it-possible-to-change-the-order-of-the-library-t3133.html
I was able to comment out the java script code that displays the Spotify block. BTW, the code is pretty easy to follow.
Good luck!
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Postby Dohmar » 14 Apr 2016, 08:39
Excellent! Thank you both, I was able to comment out the stuff I didnt want.
-D
Dohmar
