Simple Fade
Re: Simple Fade
Postby bleu34 » 06 Dec 2014, 14:54
bleu34
Re: Simple Fade
Postby ACX » 06 Dec 2014, 18:18
Re: Simple Fade
Postby lemon » 15 Jun 2015, 10:14
Hi everybody!
I've discovered runeaudio only today, seems to be a great piece to software!!!
As crossfade will we very important for my needs I'd like to know if it has already been implemented, I do not see "crossfade" in the MPD settings. Maybe it has gotten another name?
Thank you very much!!!
lemon
Re: Simple Fade
Postby ACX » 15 Jun 2015, 11:09
Hi lemon,
it has not been included yet but it will probably on the next release.
Re: Simple Fade
Postby lemon » 15 Jun 2015, 13:36
Hi ACX,
thanks for you answer.
By adding bleu34's crossfade.service file I can use MPD's integrated crossfade feature in the meantime as a workaround, can't it?
Edit: seems that it doesn't change anything. Did I miss something?
lemon
Re: Simple Fade
Postby hondagx35 » 15 Jun 2015, 16:44
Re: Simple Fade
Postby lemon » 16 Jun 2015, 07:29
lemon
Re: Simple Fade
Postby anfuca » 08 Jul 2015, 20:29
Hi, first of all, congratulations for this awesome work.
I'm very interested in the crossfade function. I have implemented as you've said but I'm getting some "troubles".
I've setted to 15 sec using the service that @bleu34 posted.
I start RuneAudio and check the crossfade time. It shows me 15. Ok.
But then, when I play music, some songs aren't crossfaded at all, and others are crossfaded but not the way that it should be, the crossfade duration is less than the 15s I've setted.
Have any of you noticed this?
Maybe is a MPD issue?
P.D: Ok. Solved. It's a MPD configuration thing about buffers size. Explained here:
Once buffer size increased, it works like a charm!
anfuca
