Simple help request
Simple help request
Postby NAP1947 » 01 Dec 2017, 21:38
I have a Raspberry Pi3, HifiBerry Dac+ Pro, and use a Mac.
I am trying to flash the SD Card using Mac Terminal and cannot seem to get the syntax correct.
I am using-
dd bs=1m if=/Norm Files and Apps/Desktop/RuneAudio_rpi02_rp3_0.4-beta_20160321_2GB.img of=/dev/disk4
I get the following error "dd: unknown operand Files"
I searched for this on the net and then added single quotes before if and after .img.
This resulted in this error, "dd: bs: illegal numeric value"
I am not skilled at terminal use and syntax so I imagine that is what I am doing wrong, I could not find a way to do this without using Terminal.
Any help and suggestions great appreciated.
Norm
NAP1947
Re: Simple help request
Postby janui » 02 Dec 2017, 10:29
Postby hondagx35 » 02 Dec 2017, 10:51
Postby NAP1947 » 02 Dec 2017, 21:56
Thank you both for your help, I tried to make the terminal commands you suggested work without success, I am sure this is lack of experience as I am pretty new to the whole Raspberry Pi environment.
Anyway, the Raspberry Pi instructions for Installing Operating System Images on Mac OS first stated to try Etcher, which I had but forgot about.
Once frustrated with Terminal I used it and was successful, RuneAudio is now running on my RPi3.
Now on the using the system.
Cheers
NAP1947
Users browsing this forum: No registered users and 41 guests
