Sleep Mode
Re: Sleep Mode
Postby tatoosh » 02 Feb 2015, 10:27
That looks good, please share your changed code ;)
tatoosh
Re: Sleep Mode
Postby cyber7 » 04 Feb 2015, 13:29
I have just added a function that does almost the same. It fades the volume over time. You can read more in the RPi forum or go to my blog and read/get the code there:
cheers
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
To err is human, to err again is machine!
cyber7
Re: Sleep Mode
Postby tatoosh » 04 Feb 2015, 16:21
just take a look at your sceenshot, nice!
I will try out out cyber7
tatoosh
Re: Sleep Mode
Postby cyber7 » 04 Feb 2015, 18:38
I will look into doing a mpc stop if the end value of the fade is zero...
cyber7
Re: Sleep Mode
Postby waves » 06 Feb 2015, 11:14
Another sleep mode alternative: use Tasker on an Android phone.
1. set up a toggle pause task ; http-get-post-commands-for-quick-mpd-play-pause-toggle-t788.html
2. create a Tasker task timer widget on the android homescreen. Click the left side of the widget to set time interval. Then click widget each time you want to activate the sleep timer.
Similarly you can make Tasker turn on RuneAudio when your Android alarm clock goes off in the morning. (Look at the alarm events in Tasker for that.)
waves
