Не получается смонтировать SMB/CIFS
Postby Urlin » 09 Mar 2018, 10:50
Help please! I have a HDD connected to the router. After upgrading the system "RuneAudio_rp2_rp3_0.4-beta_20170229_2GB "the command" pacman-Sy linux --force --noconfirm" fails to mount SMB / CIFS from the user interface. Gives an error"(112): Host is down". Before the update, everything was mounted. When checking network resources with the command "smbclient-L //192.168.1.1-U%" all disks are visible. But I can't mount them.
Urlin
Re: Не получается смонтировать SMB/CIFS
Postby janui » 09 Mar 2018, 11:28
Postby Urlin » 09 Mar 2018, 14:43
I tried to update the manual: post23634.html? Hilit = janui # p23634 janui. SMB/CIFS are mounted, but I can't install allo-digione. Allo-digione.dtbo one file absents in the /overlays / folder. If I update the "pacman-Sy linux --force --noconfirm" command, then digione is.
Urlin
Postby Urlin » 09 Mar 2018, 15:01
Dear janus. I also used the image " RuneAudio_rp2_rp3_0.4-beta_20171120_4GB_4.9.63." It got me all happy, but I can't put the webGUI on my tft screen. If you tell me how to do it, I'm going to use this image.
Urlin
Postby janui » 09 Mar 2018, 15:13
Postby Urlin » 09 Mar 2018, 15:27
Dear janus. You did not understand me. I have a screen, but it only displays the command-line console. The TV with HDMI also displays the console with the command line. I need the screen or the TV output GUI interface Runeaudio.
Urlin
Postby Urlin » 09 Mar 2018, 15:35
[/quote]Use this image as a begin point: runeaudio-0-4-beta-for-raspberry-pi2-3-t4434.html#p19960 Then follow the instructions here: post23634.html?hilit=janui#p23634 and the overlay file for the Allo DigiOne will be there.
janui[/quote]
I did, but it didn't work. Now I'll try again.
Urlin
Postby Urlin » 09 Mar 2018, 16:53
Updated according to your instruction, still not mounted: "mount error(112): Host is down Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)". Before the updates were installed fine. What to do?
Urlin
Postby janui » 09 Mar 2018, 17:26
Postby Urlin » 09 Mar 2018, 17:44
OK. Thank you janui. I will try next.
Urlin
