SMSL M8 Dac Issues
Cubietruck related support
SMSL M8 Dac Issues
Postby synologic » 21 Aug 2015, 17:22
Purchased the SMSL M8 Dac to use with Runeaudio + Cubietruck (this was selected due to the fact it can be easily battery powered by a lipo battery).
I can play almost anything with it, except 44.1 Khz FLAC files (mp3 works fine). All i get is some pops and clicks.
Had almost similar issue with Volumio, but that was solved by using dwc_otg.fiq_fsm_mask=0x3 in the commandline.txt
Any suggestions ? I really don't want to use Volumio ...
synologic
Re: SMSL M8 Dac Issues
Postby hondagx35 » 21 Aug 2015, 21:04
Postby synologic » 22 Aug 2015, 09:20
Here's the output you requested
16/44.1 Khz FLAC:
[root@runeaudio ~]# cat /proc/asound/x20/pcm0p/sub0/hw_params
access: RW_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 5513
buffer_size: 22050
16/44.1 Khz MP3:
format: S24_3LE
subformat: STD
channels: 2
period_size: 5513
buffer_size: 22050
seems to get over-sampled to 24 bit.
24/192 FLAC:
format: S24_3LE
subformat: STD
channels: 2
rate: 192000 (192000/1)
period_size: 24000
buffer_size: 96000
DSD64:
format: S24_3LE
subformat: STD
channels: 2
rate: 176400 (176400/1)
period_size: 22050
buffer_size: 88200
DSD128:
format: S24_3LE
subformat: STD
channels: 2
rate: 352800 (352800/1)
period_size: 43691
buffer_size: 174762
Debug output at http://pastebin.com/G5k0URLk
Also, the hw mixer control is wrongfully placed in mpd.conf as "Master" while there's no Master line for the M8
Hope that helps
synologic
Postby hondagx35 » 22 Aug 2015, 12:35
Postby synologic » 22 Aug 2015, 23:12
synologic
Postby synologic » 23 Aug 2015, 10:45
Just want to add that after a reboot (actually wrote Rune to nand) volume control works fine :)
synologic
Postby hondagx35 » 23 Aug 2015, 11:08
Postby synologic » 23 Aug 2015, 17:24
Everything else plays.
I have posted hwinfo on all modes.
synologic
Return to Cubietruck
