Soound Distorted with conv USB/AES
Postby J@r0d » 04 Apr 2015, 07:51
I have V192, is certified USB Audio
I have 2 problem
When play local flac 16/44, i ear little plop numéric
When i play with airplay the song is completly distorded
I teste all kernel and all profile and it same problem
I have tested Volumio and i have no problem with volumio,, tested with archphile and no pb with archphile
Have idea ?
J@r0d
Re: Soound Distorted with conv USB/AES
Postby ACX » 07 Apr 2015, 11:19
Hi, could you post your debug information via Pastebin?
Postby J@r0d » 08 Apr 2015, 06:59
Oups, sorry
http://pastebin.com/mbV3Zgx6
I have tested same plateform with hifiberry digi and i have no problem, i have tested my Musical Fidelity with external power and i have same problem
J@r0d
Postby ACX » 08 Apr 2015, 11:51
Could you also post your working MPD configuration under Archphile? It should be in /etc/mpd.conf
Postby J@r0d » 11 Apr 2015, 05:52
J@r0d
Postby ACX » 11 Apr 2015, 10:40
Umh let's test this: please disable the FFmpeg decoder plugin in the MPD section (via UI) and let me know if you notice any change with Airplay.
Postby J@r0d » 11 Apr 2015, 12:47
Is not OK with disable ffmpeg, sound is distorded with airplay and USB conv
J@r0d
Postby J@r0d » 15 Apr 2015, 13:13
I have disable all plugin ffmpeg, etc.... and i have same problem with airplay
I have placed otg_speed in config.txt and i have same problem
J@r0d
Postby tret » 02 Dec 2015, 23:34
Bump, experiencing this issue as well w/ Raspberry Pi 2, USB DAC (Arcam rDac) and RuneAudio_rpi2_0.3-beta_20150304. Can play 16/44 FLAC files without issue but Airplay streams are distorted. Have tried the various suggestions in this thread with no luck.
tret
Postby tret » 16 Jan 2016, 06:09
Found a solution and documented it here
tret
