sound blaster HD working fine with some adjust
Postby nopphong » 28 Jan 2015, 18:01
Test on raspberry pi B+ without powered HUB.It work great just rarely click sound when press change song button.
But at first the sound volume is too low even i set volume at 100%.
i have to go to console and type "alsamixer" select sound blaster and set volume to full.
But i have some confusion How can it call bit perfect if it can set volume in alsa? and if i want to set it to bit perfect how much volume i should set in alsa?
thank you.
nopphong
Re: sound blaster HD working fine with some adjust
Postby ACX » 29 Jan 2015, 02:46
Hi nopphong,
the ideal situation would be with volume set at 0dB.
Return to Compatibility list
