Sound enhancement script instead of editing several files
Postby Vhond » 27 Aug 2019, 12:41
Long time ago a topic about enhancing/tweaking the sound of Runeaudio was started. (tweaking-the-audio-performance-rpi3-t4301.html)
I applied the suggestions editing several files using the command line and was very happy with the results.
I was wandering if it is also possible to put this into a script (like somebody did for Moodeaudio: http://moodeaudio.org/forum/showthread.php?tid=749). It seems after every update these alterations are lost.
Unfortunately my Linux skills are not that good.
Or maybe somebody has another solution?
Thanks in advance, Vhond
Note: I allready sent the topicstarter a PM a while ago but haven't received an answer yet
Vhond
Re: Sound enhancement script instead of editing several file
Postby eea123 » 28 Aug 2019, 12:04
This is a great idea. I haven't touched any code but the extensive thread on audio tweaks in this forum has caught my attention.
I'll also defer to the larger group about the Sound Signature setting already built in. I'm using RuneAudio (the default?) and haven't ever tried changing it for comparison.
eea123
Postby dynobot » 28 Aug 2019, 16:19
dynobot
Postby Vhond » 29 Aug 2019, 08:54
Vhond
Postby dynobot » 29 Aug 2019, 15:42
dynobot
Postby Vhond » 30 Aug 2019, 13:13
Vhond
Postby dynobot » 30 Aug 2019, 21:48
dynobot
Postby Vhond » 31 Aug 2019, 07:44
Aren't these SOX changes possible using the MPD GUI settings screen?
Vhond
Postby janui » 31 Aug 2019, 11:56
Postby Vhond » 31 Aug 2019, 15:05
Thx Janui for your additional answer, about bitperfect: RuneAudio+R e1 includes an option to select MPD bitperfect setting.
Do you know what this exactly means (isn't this possible as option using the Rune 0.5b version)?
Vhond
