Sound output disappeared from settings (Hifiberry DAC+)
Postby washburn_it » 24 Apr 2016, 20:20
today, after turning on the RuneAudio PI2 (equipped with a DAC+ earphone jack version), I noticed that the audio output was mute and the volume control was not working.
So I went to the menu to set the audio output but I just found "HDMI out" or "Analog out" but the "HiFiBerry DAC+" was not present anymore.
Two days ago everything was working so...what could I check to fix it?
I have been using it for months till now.
Thank you, regards.
Roberto
washburn_it
Re: Sound output disappeared from settings (Hifiberry DAC+)
Postby hondagx35 » 24 Apr 2016, 23:24
Hi Roberto,
please post your debug info.
Postby washburn_it » 25 Apr 2016, 00:04
I will do it as soon as I dismount it from my car.
Thanks for the reply.
Roberto
washburn_it
Postby washburn_it » 01 May 2016, 16:54
the log exceeds 60000 chars so the forum doesn't let me publish it.
I tried to attach a TXT file with it but it's not allowed.
How can I do?
By the way, I noticed that the green led on the hifiberry board (DAC+ earphone version) is turned off even if the board is correctly connected to the GPIO port.
Thank you, regards.
Roberto
washburn_it
Postby hondagx35 » 01 May 2016, 17:04
Postby washburn_it » 01 May 2016, 17:11
Here it is: http://pastebin.com/HS1U1v1X
the release version: 0.4 (build: beta-20141216) and the board is a Raspberry PI2 (with HIfiberry DAC+ earphone version).
I look forward for any news :)
Roberto
washburn_it
Postby hondagx35 » 01 May 2016, 17:46
Postby washburn_it » 01 May 2016, 18:03
I already tried with the test image and unfortunately the only thing that it can reproduce is noise with a recurring toc-toc-toc...I think that the board is broken.
I contacted the seller (knowhowtech.de) to know the procedure for defective units.
Thank you, regards.
Roberto
washburn_it
Postby rastus » 02 May 2016, 09:48
rastus
Postby washburn_it » 02 May 2016, 10:30
I tried the "car media center" on my desk so it was not connected to the car.
When it was connected to the car, the sound was very clean, no noise.
Regards,
Roberto
washburn_it
