Sound Quality on Allo Boss Rev.1.2 between Rune / Volumio
Postby PhilHill » 15 Jan 2018, 23:22
Hi there,
compared Sound between Rune and Volumio during the last few Days.
Found an inch more at the low end with Volumio, which I cannot understand if it's
'Bit Perfect'.
Tried different Sound Signatures in Rune, but not the wanted effect;
tried finite and infinite DSP Programs (DAC: Ti pcm5122)
May Volumio tweak Frequency Response at low end ?
A bit frustrating because Rune ist far best I've seen,
lightweight, functional, fast.
Setup:
RPi3, Allo Boss v1.2, mAudio m3-8 nearfields
Any Idea ?
Kind regards & keep on with Rune ,
Phil.
PhilHill
Re: Sound Quality on Allo Boss Rev.1.2 between Rune / Volumi
Postby dror » 16 Jan 2018, 07:49
dror
Postby PhilHill » 16 Jan 2018, 11:53
Hi there,
yes I hear the difference,
especially with Joe Walsh - Turn to Stone
from his 1976 Album - You Can't Argue with a Sick Mind
Kind Regards,
Phil.
PhilHill
Postby janui » 16 Jan 2018, 13:50
Postby hondagx35 » 16 Jan 2018, 17:36
Postby PhilHill » 16 Jan 2018, 22:32
Okay,
https://pastebin.com/QGhpP5HA
Pretty much stock, i guess .
a/b Hearing on same Hardware, same Position, same Volume.
Did no Measurements so far, just Ears.
No blind Tests with others.
How to read out Interpolation Filter Volumio uses?
http://www.ti.com/product/PCM5122/datas ... it35968629
Chapter 8.3.4.2
@Frank
I'd like to DSD native to pcm5122.
If I set this, only white Noise is heard.
How to add ?
Kind Regards,
Phil.
PhilHill
Postby dror » 17 Jan 2018, 07:45
dror
Postby PhilHill » 17 Jan 2018, 14:50
:lol:
https://pastebin.com/GFihCUbQ
soxr i see... okay.. that's the difference in sound ?
resampling doesn't add anything which is not there, does it ?
kind regards,
phil.
PhilHill
Postby andfor » 17 Jan 2018, 17:14
I just want to weigh in here with an observation... I recently implemented Sox resampling with Rune 0.4b and was really pleased with the results. It made the world of difference. Or so I thought...
Janui tested the same implementation and had the opposite opinion, which got me thinking.... I decided to disable the resampling for a while to see if I really noticed a difference or if it was just a placebo.
During this time without resampling enabled I rearranged my living room, where the system is situated, and accidentally moved the speakers closer to the rear wall.
The result was an instant and significant change in the quality of the sound. That simple change effected the sound more than any amount of fiddling about with the audio source has ever done. In fact it resolved a specific issue I was having with the sound that I was contemplating all kinds of interventions to try and fix.
The moral of the story is: when you're down in the tiny details you miss the bigger picture. The fact is that no matter how bit-perfect and pristine your source is, the source is not the sound. The sound is fluctuations in air pressure coming out of the speakers, bouncing around the room and hitting your eardrums. Yes you can improve things with better equipment, but digging around for tiny improvements and arguing about the results as though they are anything other than subjective is just nonsense. Especially when speakers a few inches closer to a wall makes more of a difference.
I still love doing it though..... can't resist fiddling. :D
andfor
Postby PhilHill » 17 Jan 2018, 19:18
Hi Andfor,
i followed your Conversation with Janui about SOX, but had no time to give it a try.
(to be honest, I don't know how MPD communicates with SOX, added
resampler plugin soxr etc. to my mpd.conf,
which returned with an error)
(I'm not sure if I'd to do more than telling MPD about SOX,
found this: https://www.musicpd.org/doc/user/resamp ... _resampler )
Luckily at this point, my dog heard nature's call, so i went for a walk :-D
According to Room Acoustics, you're absolute right.
Best Bang for the Buck is understanding Roommodes, damping Reflections and Basstraps.
Kind Regards,
Phil.
PhilHill
