Sound Quality problem with HD files
Postby Jean-Louis P » 28 Jul 2014, 13:15
Hi all
I am feeding a waveIO board from Luckit through USB, which goes in I2S to Najda Digital XO. I have two issues:
1/ Everything is okay with CD standard files. I tried HD 24bits/96kHz and there are a lot of clicking during the playback (not between tracks).
2/ there is a single click between tracks, CD or HD no matter
Thanks for help
BR
Jean-Louis
PS : I acquired a log file below if this may help :
###### System info ######
Linux version 3.12.6-2-ARCH (nobody@root-chroot-copy) (gcc version 4.7.2 (GCC) ) #1 SMP Mon Jan 6 12:59:03 MST 2014
system load: 0.00 0.01 0.05 1/80 22383
HW platform: BeagleBone Black (04)
playerID: 045ba7f8665618e23bc65bba5f1f702c5f
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k3.12.6-2-ARCH.
0 [L20 ]: USB-Audio - Luckit USB Audio 2.0
Luckit Luckit USB Audio 2.0 at usb-musb-hdrc.1.auto-1.2, high speed
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 1
subdevices_avail: 1
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
interface #0 stream status: (/proc/asound/card0/stream0)
Luckit Luckit USB Audio 2.0 at usb-musb-hdrc.1.auto-1.2, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "112254"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf0eae94"
.ARM.exidx.init.text= "0xbf0eae8c"
.ARM.exidx = "0xbf0ed334"
.ARM.extab = "0xbf0ed2bc"
.ARM.extab.init.text= "0xbf0eae80"
.bss = "0xbf0f11e4"
.data = "0xbf0ed898"
.exit.text = "0xbf0e919c"
.gnu.linkonce.this_module= "0xbf0f1080"
.init.text = "0xbf0fa000"
.note.gnu.build-id = "0xbf0ed874"
.rodata = "0xbf0e91a8"
.rodata.str1.1 = "0xbf0eaf2c"
.strtab = "0xbf0ff328"
.symtab = "0xbf0fa048"
.text = "0xbf0dd000"
__param = "0xbf0eae9c"
hardware platform: BeagleBone Black
current orionprofile: RuneAudio
kernel scheduler for mmcblk0: [noop] deadline cfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,relatime,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=253580k,nr_inodes=63395,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/root /var/tmp ext4 rw,relatime,data=ordered 0 0
/dev/sda1 /mnt/MPD/USB/Ref\040Music\040JLP fuseblk rw,nosuid,nodev,noexec,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
###### mpd.conf ######
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
db_file "/var/lib/mpd/mpd.db"
log_file "/var/log/runeaudio/mpd.log"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
state_file "/var/lib/mpd/mpdstate"
user "mpd"
bind_to_address "any"
port "6600"
log_level "default"
zeroconf_enabled "yes"
zeroconf_name "runeaudio"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "20%"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
gapless_mp3_playback "yes"
auto_update "no"
mixer_type "disabled"
group "audio"
max_connections "20"
decoder {
plugin "ffmpeg"
enabled "no"
input {
plugin "curl"
audio_output {
enabled "no"
type "alsa"
name "USB-Audio"
device "hw:0,0"
dsd_usb "yes"
audio_output {
enabled "yes"
type "null"
name "Null"
###### PHP backend ######
php version: 5.5
debug level: 2
###### SESSION ######
STATUS: 1
SAVE PATH: /run
###### SESSION DATA ######
Array
[orionprofile] => RuneAudio
[cmediafix] => 0
[playmod] => 0
[ramplay] => 0
[sessionid] => ng0imu4gev9vd1sb7508squgp7
[mpdconfhash] => 4ada794c0fcb95a91f7ac4c2ab737694
[lastfm_apikey] => ba8ad00468a50732a3860832eaed0882
[netconfhash] => 643f8967af551f683b3cfd493950c550
[mpdconf_advanced] => 0
[netconf_advanced] => 0
[dev] =>
[sourceconfhash] => d41d8cd98f00b204e9800998ecf8427e
[sourceconf_advanced] => 1
[debug] => 2
[hiddendebug] => 0
[opcache] => 1
[playerid] => 045ba7f8665618e23bc65bba5f1f702c5f
[hwplatform] => BeagleBone Black
[hwplatformid] => 04
[airplay] => 0
[scrobbling_lastfm] => 0
[scrobbling_librefm] => 0
[scrobbling_jamendo] => 0
[spotify] => 0
[db_version] => 1.2
[udevil] => 1
[coverart] => 1
[volume] => 0
[ao] => 0
[ntpserver] => ntp.inrim.it
[hostname] => runeaudio
[w_queue] =>
[w_queueargs] =>
[w_lock] => 0
[w_active] => 0
[w_jobID] =>
[debugdata] =>
[netconf] => Array
[eth0] => Array
[ip] => 192.168.178.25
[state] => pause
[notify] =>
Jean-Louis P
Re: Sound Quality problem with HD files
Postby Jean-Louis P » 04 Aug 2014, 09:39
Jean-Louis P
Postby Jean-Louis P » 04 Sep 2014, 13:20
Vacations ended :D
Any ideas Andreas ?
Jean-Louis P
Return to Beaglebone Black
