Sound very low with USB DAC Dacmagic plus
Postby parisbyday » 07 Nov 2016, 23:29
I connect a RPI3 with Dacmagicplus via USB but sound level is very low. i have to increase to volume to highest level on DAC and AVR to hear something with a lot of distorstion.
Tried differents options for volume control on runaudio/MPD settings
It works perfectly with volumio so i dont think the DAC is the issue. put the log here http://pastebin.com/xFMAQ2sD
Version used is the latest RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB
Any idea ?
Thanks in advance,
Jean.
parisbyday
Re: Sound very low with USB DAC Dacmagic plus
Postby dror » 08 Nov 2016, 07:33
Try checking alsamixer levels.
Also check for Hardware/Software volume controls in the MPD tab in the UI settings.
dror
Postby parisbyday » 08 Nov 2016, 07:50
Many Thanks for your feedback,
What are the steps to modify the aslamixer configuration ? Via ssh ?
Thanks for your help.
Jean
parisbyday
Postby hondagx35 » 08 Nov 2016, 08:13
Hi Jean,
please see here:
post17390.html#p17379
Postby parisbyday » 08 Nov 2016, 19:30
with alsamixer i cannot change any volume level, however i can see that cambridge audio dac is selected (version 2.0)
Any thoughts ?
Jean.
parisbyday
Postby hondagx35 » 09 Nov 2016, 09:15
Hi parisbyday,
what controls are available within alsamixer?
Postby parisbyday » 09 Nov 2016, 19:38
Finally and could be a coincidence, my Cambridge DACMAGICplus seems to have an hw issue.
Sound level is low (have to push volume to higest with distortion to hear something). Tested a CD player same issue.
The steps i have followed are :
volumio usb audio 1.0 => OK
change on DAC from usb audio 1.0 to 2.0 for 192 Khz support
volumio usb audio 2.0 => OK
change from volumio to runeaudio and it did not work (low volume issue).
Now i put a Hifiberry DAC+ Pro but it is not recognised.
Do i need something to enable the IS DAC driver ?
it works perfectly with volumio.
thanks,
jean.
parisbyday
Postby hondagx35 » 09 Nov 2016, 22:27
