Spotify Connect on RuneAudio
Re: Spotify Connect on RuneAudio
Postby janui » 13 May 2019, 21:19
Postby Ema_82 » 13 May 2019, 21:44
Ema_82
Postby dynobot » 13 May 2019, 22:53
dynobot
Postby Ema_82 » 13 May 2019, 23:11
Already tried with untouched config.txt: same error :-(
Ema_82
Postby dynobot » 13 May 2019, 23:33
dynobot
Postby Ema_82 » 13 May 2019, 23:43
Thanks for the help but I have already turned off the pc and I can only do this test tomorrow.
I did not enable the I2S kernel
Ema_82
Postby dynobot » 14 May 2019, 00:02
dynobot
Postby Ema_82 » 14 May 2019, 09:12
I'm at work, so I can't do the tests now, but I think it is useful to make some considerations:
1) RuneAudio, via its interface, works like a charm. I played music from a powered HDD without any problem and, when I tried it, I didn't have to change anything in the config.txt.
2) I'm pretty sure that the spotifyd files are in the correct paths.
3) I would tend to exclude that the problem could be in spotifyd.conf, considering that "Every field is optional; Spotifyd can even run without a configuration file" (https://github.com/Spotifyd/spotifyd)
4) The .service file is in folder path /usr/lib/systemd/system/ and, as you can see in the picture in my first post, it seems to be correctly found and loaded, but it stops immediately. So I think there is something wrong with this service, and maybe the log part I attached could be useful to find what causes the problem.
Ema_82
Postby dynobot » 14 May 2019, 14:48
dynobot
Postby Ema_82 » 14 May 2019, 21:27
Ema_82
