Spotify Connect on RuneAudio
Postby tml3nr » 07 Apr 2018, 16:02
tml3nr
Re: Spotify Connect on RuneAudio
Postby grofweg » 18 Apr 2018, 07:27
grofweg
Postby grofweg » 18 Apr 2018, 18:50
Unfortunately, after a full day of listening things didn't turn out that good. More than once the music stopped completely. A reboot was required to get things going again.
Anyone else having similar issues?
Sent from my Redmi 3S using Tapatalk
grofweg
Postby tml3nr » 19 Apr 2018, 01:13
tml3nr
Postby grofweg » 19 Apr 2018, 09:41
Thanks, I'll try the first 1 as well.
Let's see if that one is more stable.
grofweg
Postby tml3nr » 19 Apr 2018, 11:41
tml3nr
Postby grofweg » 20 Apr 2018, 17:17
Unfortunately this doesn't work either. Same problems.
Never mind it was worth the try. May be this weekend I'll try again with h an RP2.
grofweg
Postby tml3nr » 21 Apr 2018, 07:28
Thank you very much for your test. Maybe it would be better on RPi2. All 3 versions of spotify-connect-web work fine on my test with RPi2.
i have both RPi2 & RPi3. But i prefer RPi2 because it's low noise, sound more cleaner.
tml3nr
Postby kaczor189 » 26 May 2018, 18:35
I've got a problem with step: ./spotify-connect-web.sh install. Putty claims there is no space left on divice, while I have a 16GB card !
kaczor189
Postby tml3nr » 27 May 2018, 01:46
tml3nr
