Spotify does not react [SOLVED]
Postby RaspiPie » 02 Apr 2016, 11:38
Hi all,
I have a RPi2 with RA latest version. For a while I was running Spotify through it and everything worked fine. But since two days I cannot get it to work anymore. Whenever I click on the >Spotify< button in the library, literally nothing happens. I already checked if it has anything to do with my account. I have a Spotify premium account and streaming works through their page (play.spotify.com). So this is not the reason. Also I have turned off and turned on the Spotify player in Settings/Feature management but this did nothing as well. Still I cannot run Spoity with the RuneAudio UI. What happened ? Any clues ?
Felix
RaspiPie
Re: Spotify does not react
Postby hondagx35 » 02 Apr 2016, 13:51
Postby RaspiPie » 02 Apr 2016, 13:59
RaspiPie
Postby hondagx35 » 02 Apr 2016, 14:38
Re: Spotify does
Postby RaspiPie » 02 Apr 2016, 14:41
just recently I installed spotify-connect to solve my problem. This also didn't work. It seems that the error which I posted is not related to the Spotify daemon (spopd) of Runeaudio. I actually don't need Spotify-connect and would be happy to run Spotify through Runeaudio. Can you help with that ?
Felix
RaspiPie
Postby RaspiPie » 02 Apr 2016, 22:02
Hi again,
Unfortunately I still have not solved my problem, which is getting the spotify daemon to work under Runeaudio (spopd). Again this is what happend:
Everything worked fine until two days. Before when I clicked on >Spotify< in the library a dialog appeared and I could change between the MPD and Spotify daemon. Now since two days nothing happens when I click on the >Spotify< button.
This is what I have tried:
reboot
turn off and turn on Spotify in Settings/Features management
use another premium spotify account
reinstall Runeaudio
Nothing helped so far. I am really desperate and don't understand what is going on. Please help.
Felix
RaspiPie
Postby hondagx35 » 02 Apr 2016, 22:22
Postby RaspiPie » 02 Apr 2016, 22:33
RaspiPie
Postby hondagx35 » 02 Apr 2016, 23:15
Postby RaspiPie » 02 Apr 2016, 23:50
Hi Frank
I am pretty sure that yes. To be absolutely sure I will install it again. But not today. I will do it tomorrow.
Felix
RaspiPie
Users browsing this forum: Baidu [Spider] and 45 guests
