Spotify does not work.
Re: Spotify does not work.
Postby pietpara » 14 Jan 2017, 21:24
Is it not strange that in the overlays folder some of the values for dtoverlay do not appear?
For instance:
rpi-dac-overlay
Pi3-disable-bt-overlay
Should they not be in that folder?
pietpara
Postby pietpara » 14 Jan 2017, 21:27
I tried by commenting rpi-dac-overlay and uncommenting rpi-dac and now I get sound.
Question, is this ok? Or is this some suboptimal setting?
Maybe I should comment pi3-disable-bt-overlay too and uncomment pi3-disable-bt?
pietpara
Postby pietpara » 14 Jan 2017, 22:37
Hello again,
I have tried Spotify now and it works!
There is a pop sound when tracks change. Is there a known solution to that?
So, apart from popping the only question I have remaining is whether my config.txt is setup correctly or not, as explained in previous posts?
Thanks a lot
Pietpara
pietpara
Postby hondagx35 » 14 Jan 2017, 23:44
Postby betocool » 15 Jan 2017, 01:23
Good day guys,
Instead of starting a new thread, I thought I'd ask here first.
MPD works fine.
When I switch to spotify, it takes a bit, not much, but then it shows zero Favourites "Favourites (0)" and nothing else. Inside the favourites there is nothing. I have a premium account, and login information should be ok. I haven't changed it. It worked a week or two ago... I don't use spotify too often, but this is the first time I see that.
Any troubleshooting ideas?
Cheers,
Albert
betocool
Postby hondagx35 » 15 Jan 2017, 12:42
Hi Albert,
please see .
Postby pietpara » 15 Jan 2017, 19:24
pietpara
Postby hondagx35 » 15 Jan 2017, 22:32
Hi Pietpara,
as far as i know Audiophonics is working on a better DAC integration.
i am in contact with Audiophonics and will inform you as soon as possible.
