Spotify does not work.
Postby flovato » 29 Dec 2016, 10:14
Hi guys,
it worked before, suddendly is mute.
Music from SSD it's ok only Spotify dont work, look library and it seems playing but... silence
After many tests with Raspberry PI 3 ask if you have same problems ?
flovato
Re: Spotify does not work.
Postby hondagx35 » 29 Dec 2016, 11:33
Hi flovato,
please try this:
- switch to spotify
- select and play a song
- go to MENU->MPD and select a different audio output
- change the output back to the old one.
Postby pietpara » 13 Jan 2017, 11:41
I also cannot get Spotify to work.
I just opened Spotify in the library where I chose "Spotify" form the list. I then get an endless spinning wheel saying something about "launching backend...." which never stops.
I went to settings and activate Spotify, added my username and password, but that didn't change anything.
I then noticed that my username was incorrectly spelled, so I want to change it. But now, whatever setting I try to change and hit "apply", the settings are not saved. Even after a reboot, any change in settings is disregarded and reverts back to old settings.
How can I solve this, please?
thanks
Pietpara
pietpara
Postby hondagx35 » 13 Jan 2017, 14:56
Hi Pietpara,
do you have a premium account?
On the playback screen click on Spotify and change the player back to MPD.
I tested Spotify on my Rasptouch and it works like it should.
Do you use the touch screen or are you connected with a remote browser?
Postby pietpara » 13 Jan 2017, 15:03
I wanted to add that it seems that I cannot change any setting anymore, neither in the settings menu nor in the MPD menu. Nor can I change volume, set to hardware. Rebooting doesn't help.
My debug log is here http://pastebin.com/QC33Sb3i
I hope someone can give me some hints.
Thank you in advance!
Pietpara
pietpara
Postby pietpara » 13 Jan 2017, 15:07
pietpara
Postby ianhaynes » 13 Jan 2017, 15:14
As reported in the Bug section I can't get Spotify to work either. I have a Premium account, can select a playlist from it which then shows in the queue but nothing will play.
Ian
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby pietpara » 13 Jan 2017, 15:20
pietpara
Postby hondagx35 » 13 Jan 2017, 15:22
Postby ianhaynes » 13 Jan 2017, 15:28
As noted I can see the list of songs but nothing will play. I've tried switching back to MPD and then back to Spotify again but it makes no difference.
I'm using a new, unmodified, untweaked version of the the latest build.
Ian
ianhaynes
