Spotify playlists not visible
Re: Spotify playlists not visible
Postby pierce » 30 Mar 2017, 00:10
I can't figure out how to play anything, either. configure and enable spotify, then select it, then the player shows nothing. 0.3-beta , raspi3 w/ dac+, works fine playing files via SMB from my FreeNAS, and various streaming URLs.
pierce
Postby hondagx35 » 30 Mar 2017, 07:51
Postby wookiee » 30 Mar 2017, 09:18
^ I have all of those Frank. In my case, Spotify used to work ok before it stopped a few weeks back so settings wouldn't be an issue
wookiee
Postby irishwill2008 » 30 Mar 2017, 09:32
irishwill2008
Postby wookiee » 31 Mar 2017, 00:39
Thanks, will post a little later
wookiee
Postby ultrahomme » 07 Apr 2017, 09:56
I have the same issue.
It use to work perfectly before in 2016
switching to spotify renderer seams OK but doesn't change the renderer(the music from another renderer still flows, air play)
when trying to access my playlists, a infinite spinning wheel comes.
spotify premium family
Rpi3 build 0.3
in france
ultrahomme
Postby pierce » 08 Apr 2017, 02:03
pierce
Postby ultrahomme » 15 Apr 2017, 14:59
this is why i could not connect to Spotify,
It is now smoothly running
in my case one the device attached to our network was badly configured.
the network default getaway IP address on our NAS was wrong.
Hope it helps someone
ultrahomme
Postby irishwill2008 » 24 Apr 2017, 09:21
irishwill2008
Postby ericmcmahon » 10 Jan 2018, 04:32
2 ways to solve your problem:
A. Subscribed as premium membership
B. Downloading your Spotify Music for Offline listening.
As for A, it seems easy to get the solution.
As for B, maybe you need A for helping you .
Both 2 plan you can take into consideration for when you don't want to subscribe to the premium membership, plan B is optional.
ericmcmahon
