Start playing on boot
Postby smonaghen » 11 Dec 2014, 18:21
Is there a way to make RuneAudio start playing after boot? I would like to use it on a RPI with no network, no keyboard, headless, with music stored on usb flash after initial set up. This would allow for use in a vehicle, or with anyone's stereo without any interaction.
Thank you very much,
smonaghen
Re: Start playing on boot
Postby cmh714 » 11 Dec 2014, 18:33
if you shutdown the player when its playing, its been my experience that the same will start up automatically on next boot...I also believe the command to start mpd can be called with the appropriate parameters to start music as well.
Postby smonaghen » 11 Dec 2014, 18:48
Tried shutting down while playing...no luck. What "commands" would cause RuneAudio to auto start in the mpd?
smonaghen
Postby cmh714 » 11 Dec 2014, 19:08
actually it would be mpc commands, see here: http://linux.die.net/man/1/mpc
I'm sure ACX can help better....
Postby ACX » 12 Dec 2014, 02:30
mpc play is the cli command that will tell MPD to start the playback (if you have tracks loaded in the queue, of course).
Just use it in a bash script and make it run at boot.
Postby rasti » 21 May 2015, 16:35
I'd also like to do that.... could someone provide step by step instructions
with code lines how to implement that ? I am not really linux literate...
Ralf
rasti
