Static IP Issue
Static IP Issue
Postby ian2000t » 17 Sep 2015, 14:22
Hi, I am having some problems with my RuneAudio on my Raspberry Pi B with static IP ethernet eonnection.
I used the UI and set the network to a static setup. Worked fine, and is accessible from any home PC (and externally with port 80 forwarded).
However, if I reboot the device, when it boots back up it has no network connections and is not accessible from anywhere. I logged in with keyboard and screen, and "ifconfig" shows eth0 has no IP.
I edited the /etc/dhcpd.conf and manually added IP, DNS and Gateway settings. Restarted dhcpd service and all working again.
This happens everytime I reboot the Pi though. /etc/dhcpd.conf is still populated, but I have to restart the service everytime I reboot it.
Are static IP's not supported in RuneAudio?
ian2000t
Re: Static IP Issue
Postby hondagx35 » 18 Sep 2015, 11:30
Re: Static IP Issue
Postby washburn_it » 17 Oct 2015, 18:41
I'm having the same issue, I tried what suggested but it didn't fix it.
So I had to reinstall the image from zero.
Where does Rune save the network settings?
Roberto
washburn_it
Re: Static IP Issue
Postby ian2000t » 15 Nov 2015, 18:52
I gave up. Instead I setup a static DHCP lease on the router (I can do this as I use dd-wrt), and run RuneAudio in DHCP mode.
ian2000t
