Steinberg interface on Raspberry
Postby ds_le_moulin » 09 Jul 2020, 08:21
I have a Steinberg Ur22C I would like to use as a sound interface. It connects trough USB. Only reason I am willing to use it, is that sound quality is significantly better on this than trough any build in computer sound card. I listen to internet concerts and therefore, a good sound quality is very much enjoyed.
Situation : I connect the UR22 before starting the Raspberry. I boot it, and on volume button right click and select Steinberg UR22C. I understand that it has recognized what it is because it is in the menu. I reboot the Raspberry and..
Problem : there is absolutely no sound coming out of it.
Question : Would Rune Audio make that somehow work ? If no, does someone has an idea why it doesn't / won't work ? Has someone experimented successfully this combination ?
Thanks for your help !
ds_le_moulin
Re: Steinberg interface on Raspberry
Postby ds_le_moulin » 10 Jul 2020, 06:52
I tried the quick start guide. There is something anyways that I didn't quite get : Raspberry has only one SD card spot, and after I went trough the procedure, it didn't start at all anymore.
I thought I could partition my SD card, but the option is not possible to activate.
Any hints ?
ds_le_moulin
Users browsing this forum: No registered users and 51 guests
