Store the music in the SD card? or USB?
Postby will » 19 May 2014, 12:56
As the BBB only have 1 usb, can I use a usb hub to plug the USB DAC and a USB thumb drive to store my music?
Or is that possible to store the music in the SD card?
I tried to create a folder named "music" under the "MPD" however it was so strange that I can't access (via SMB from Mac) the folder anymore after I copied several music file. I'm using a 8G micro SD card.
What can I do? :?:
Thanks :D
will
Re: Store the music in the SD card? or USB?
Postby ACX » 19 May 2014, 13:03
Storing music in a NAS and accessing it through ethernet is the ideal solution with BBB.
In alternative, you can put music on your SD card (take a look at for it) or use a USB hub (possibily the worst choice, but it should work).
Return to Beaglebone Black
