Postby hondagx35 » 17 Dec 2015, 22:05
Postby nanoqui » 18 Dec 2015, 04:41
nanoqui
Postby hondagx35 » 18 Dec 2015, 10:47
Hi nanoqui,
did you already update the midori local config like described ?
Postby nanoqui » 18 Dec 2015, 18:23
Yes, I did... everything should be up to date.
nanoqui
Postby nanoqui » 18 Dec 2015, 22:29
nanoqui
Postby Perjan » 20 Dec 2015, 10:43
Perjan
Postby rlsten » 04 Jan 2016, 01:47
I finally got a 7" Touchscreen and I am thrilled that there is a Rune Audio interface! I thought I would have to reinvent the wheel and use MPD with some kind of front end, but to have Rune is exactly what I wanted.
I've tried it and so far it's great; as others have noted, the touch controls are not yet perfectly responsive, but I trust these kinks will be worked out.
Is development on this still ongoing?
Rod
rlsten
Postby hondagx35 » 04 Jan 2016, 09:52
Postby tinue » 05 Jan 2016, 12:27
Hello
My Runeaudio image suddenly stopped working, so I had to burn a new image. The one made to support the Pi image seems to be the latest one available, so I took this one. I don't have the display connected yet, so I can't give feedback yet about this part of the image.
The image works nicely! Apparently the Hifiberry Amp is now configured all the way: Hardware volume control works.
I have one problem though: When I go to "Networks" and click "WLAN0", no hotspot is ever being shown. It just shows "scanning for networks". This is with IE11 / Windows 10.
It's not a wlan issue as such, I think. The same page works fine when I use my Mac with Safari to access "runeaudio.local". It also works with the Edge browser on Windows 10. Just IE11 seems to have a problem.
Thanks for the great work! Martin
P.S. Here is the debug info, in case it's of any use: http://pastebin.com/g8G52eTs
tinue
Postby Cayenne » 15 Jan 2016, 15:36
I have a pi with a hifi-berry that works great with the standard RuneAudio(web server). I would really like a local display, I have the Rpi 7" touch and downloaded the image You are posting--upon boot I get all the way to the user/logon and use root/rune and then does nothing but show the command line. I have it connected to the net via ethernet in case it needs to update. What could I be doing wrong I'm confused. Thanks for all Your hard Work! Carl
Cayenne
