Postby morias » 28 Feb 2016, 11:26
Over the weekend I installed a Hifiberry Dac+ Pro on the back of my touchscreen. It will be fully encased in my case once I get a drill big enough but that is a project for next weekend.
On installing the card it was not recognised. I followed this thread:
hifiberry-dac-pro-t2954-10.html
And enabled the following in /boot/config.txt
device_tree_param=i2c_arm=on
device_tree_param=i2s=on
I also enabled:
device_tree_overlay=hifiberry-dacplus
As I could not find:
dtoverlay=hifiberry-dacplus
Making those changes got it working. Is that the correct way of enabling the sound card or is there a better way to do it?
morias
Postby hondagx35 » 28 Feb 2016, 12:20
Postby morias » 06 Mar 2016, 01:07
This is my player with a Hifiberry Dac+ Pro mounted in the case. It is a tight fit. I got the inspiration from the instructable guide.
Sent from my iPhone using Tapatalk
morias
Postby c-moll » 08 Mar 2016, 16:37
does this image run on a new Pi 3? I'ved tried, but it is already hanging at startup and showing only the rainbow colored background.
Chris
Raspberry Pi 3B - HifiBerry Amp+ - Raspberry Pi 7" Touchscreen
c-moll
Postby hondagx35 » 08 Mar 2016, 17:50
Hi Chris,
i'm working on a new image for the RP3.
It will also have the local browser option as this one.
See also .
Postby tinue » 11 Mar 2016, 18:34
My speakers are a bit off-center, so I usually use alsamixer to shift the balance a bit to the left. Do you know why alsamixer doesn't work in this image?
Thanks! Martin
[root@runeaudio ~]# alsamixer
alsamixer: error while loading shared libraries: libformw.so.5: cannot open shared object file: No such file or directory
P.S: I know this has been asked twice so far, but I haven't seen an answer or solution.
tinue
Postby hondagx35 » 11 Mar 2016, 19:47
Postby tinue » 16 Mar 2016, 20:00
Thanks! The new image works great on the Pi 2, and Alsamixer works as well.
The volume control seems different: Before I was at about 20-30, now I need >50 to hear the same volume. Was this switched from logarithmic to absolute?
I am using hardware volume control on the Hifiberry Amp+.
tinue
Postby c-moll » 18 Mar 2016, 17:34
I installed the new image and logged in as root. When I start x-window I get the UI of runeaudio showing the playback screen. But I can do nothing, no clicks will be accepted. What can I do?
Thx.
Chris
c-moll
Postby hondagx35 » 18 Mar 2016, 18:06
