Postby wridley » 21 Apr 2016, 22:56
wridley
Postby PiFi » 22 Apr 2016, 12:32
The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom. - Asimov
PiFi
Postby hondagx35 » 22 Apr 2016, 13:14
Postby PiFi » 22 Apr 2016, 17:59
you're very welcome. Thank you (and all other contributors) for creating such a great system! I'm loving it.
From your comment, it would seem that I'm not using the latest image then (I'm using RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img). Can you point me to where I can find the latest?
Thanks!
PiFi
PiFi
Postby piccy » 08 May 2016, 12:09
Am using the touch display and apart from a wish to make control icons larger it works ok , it also seems to be more responsive when used with a pi3 which i have just fitted in place of pi2 ,
my question is are there any issues with screen burn on lcd monitors ? , if there is can a screensaver be implemented or the screen blanked when not been touched for say 5 mins ?
thanks
piccy
Postby morias » 08 May 2016, 13:14
morias
Postby darknix » 06 Jun 2016, 08:44
darknix
Postby hondagx35 » 06 Jun 2016, 09:43
Postby darknix » 07 Jun 2016, 02:10
Frank,
Thank you very much for the reply.
I am working on it.
Edit:
I have finished the steps in
Unfortunately the touch is still does not work after reboot.
darknix
Postby raid3868 » 12 Jun 2016, 02:09
I have raspberry pi 3 + DAC + 7" LCD touchscreen and think work very well, Thank you to renuaudio hardworking to
bring this feature and is great.
Got some issue below.
1). On local lcd on top of the left hand side is display clock instead of Renuaudio logo, and the clock display is different from the system time. How can i change to Renuaudio logo or get to display the actual system time?
2). Possible to set the brightness of lcd on startup?
Hope someone can help.
Thank you very much.
raid3868
