Postby Syco54645 » 23 Jun 2016, 05:42
Syco54645
Postby vanilla8 » 02 Jul 2016, 21:17
vanilla8
Postby hondagx35 » 02 Jul 2016, 22:51
Hi vanilla8,
please try .
Postby vanilla8 » 03 Jul 2016, 10:10
Thanks very much Frank, that solved it :)
vanilla8
Postby AudioplatinumService » 11 Jul 2016, 13:38
I am new here, but I read this forum for some time. Here I have 2 Rune players and almost all work great, but..I have one problem with 7" RPi LCD. I try last image for Rune and connect 7" LCD and I find one problem. Let me try explain. When I boot Rune, all is fine, then If I touch lcd several times in one place (I want to turn up volume) after several presses screen go to white, music play, I can access thru web browser but screen is permanent white. I have mouse attached and If I press right mouse key I get menu from Midori browser but I can`t get local browser with Rune UI on LCD without restart. After restart, all is ok.
Any ideas?
Debug info:
Interface is IQAudio / RaspyPlay4
Best Regards,
Raf,
Postby hondagx35 » 11 Jul 2016, 15:44
Postby AudioplatinumService » 11 Jul 2016, 18:24
Postby Trima » 20 Jul 2016, 10:05
Hi guys,
I'm new at this forum, you did a great job with this GUI!
First of all, I'm new to RPi and quite new to linux, so I'm not an expert at all.
I'm using an RPi 3 with its official 7" Touchscreen monitor (connected to RPi via DSI).
I burned the RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img on a 4GB SD and started using the system.
At first sight everything looked to be ok, but I suddenly noticed that I couldn't use my touch...the display works fine on the "graphical" point of view, but I'm not able to control nothing without a mouse.
Can someone help me to understand what I have to do to enable the touch function?
Thanks so much.
BR.
Trima
Postby nicko500 » 25 Jul 2016, 16:25
Touch panel should works with downloaded image, without any setting.
Maybe touch panel flat cable is not correctly connected ?
nicko500
Postby sandbox » 27 Sep 2016, 16:15
sandbox
