Postby rpt007 » 29 Jan 2017, 20:06
rpt007
Postby hondagx35 » 29 Jan 2017, 22:10
Postby rpt007 » 29 Jan 2017, 23:02
thanks for your reply.
The modification now set the screen the way I wanted to have it.
But now the Touch screen is in the same position as before, which means it works in the opposite direction (left is right and up is down).
I googled a bit for that issue. The information which I found looks quite complicated, dealing with xinput etc. -> but will give it a try only tomorrow as it's getting late and my concentration ... and before I screw up everything. Or is there an easy way to get the touch in the right position/orientation? Wouldn't it be a deal having a script which gets along with any display information, reads the enabled orientation of the screen and draws the touch orientation into the adequate position automatically? Or am I on the wrong track?
NFS: yes. I think so, but I am at the end of my patience and test constellations. Will stay with the easier SMB as I don't experience any speed problems (this was what I found why NFS should be better than SMB).
Anyway, thanks a lot; I am still new to all this stuff and thrown back into my old DOS days ;-)
Raimund
rpt007
Postby L4C » 28 Mar 2017, 06:31
Very nice to use the runeaudio on raspberry with display as a stand alone player. The only thing what I missing some screen saver options.
I know currently it has screen saver in playback mode where display the song info this is nice (it would be nice to see the clock on the same screen there is a bunch of space left on the screen).
I'm really missing to see an option to automatically turn off the display where the device in stopped state (idle)
This can be a same timeout like the screen saver in play state. I know the display can be turned off manually but that is requires 3 touch on the screen which is quite uncomfortable.
L4C
Postby tinue » 14 Apr 2017, 09:01
I have turned off the display using the menu entry in the "Turn Off" section. This seems to heave been a permanent thing, though. Reboot, even a power cycle, leaves the screen turned off (not even the backlight comes on). How do I re-enable the screen? I am using the 0.4 beta that was recently published. The screen is the official 7" touchscreen monitor. The Pi is a Model 2. DAC is the Hifiberry Amp+.
Thanks! Martin
tinue
Postby hondagx35 » 14 Apr 2017, 14:55
Postby tinue » 14 Apr 2017, 21:14
tinue
Postby Yeti » 24 May 2017, 19:19
I only have "power off" and "reboot" under the "Turn Off" tab,no "display off".What am I missing here?
Yeti
Postby morias » 25 May 2017, 07:59
morias
Postby hondagx35 » 25 May 2017, 10:44
Hi Yeti,
- device (RP0, RP1 or RP2/3)?
- software version?
@morias:
This feature is available since April 2016.
