Postby dom.efendi » 16 Jan 2018, 18:51
Hey
I've installed the latest version today on RPi 3 (RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img) I'm also missing the "power off" feature in the turn off menu :?
cheers
Dom
dom.efendi
Postby AlleyCat » 02 Apr 2018, 14:51
I am running Rune 0.4b and the screensaver feature doesn't work on the LCD 7". The screen turns off on manual command from the Menu, but the screensaver doesn't work.
Any suggestions?
Also, the buttons and text in Chromium are too small to be useful. I found instructions for changing the defaults for Miduri. How do I make the changes on Chromium?
Thank you.
AlleyCat
Postby AlleyCat » 03 Apr 2018, 22:19
Any reply?
Thanks.
AlleyCat
Postby hondagx35 » 04 Apr 2018, 08:01
Postby marvt74 » 04 Apr 2018, 13:55
I've recently just bought the Raspberry Pi 3 B+, it's the first time i've had anything like this so looking forward to having a play.
My last attempt to use anything like Rune was the Vortexbox software about 6 years ago. I found it worked well but i struggled when it came to making changes on a script line basis.
I'd ideally like this unit to run in the same style as the old Squeezebox touch. How easy is that to implement ontop of the base software? I've scrolled back a few pages and see lots of lengthy code text boxes and wonder if it's going to be beyond me!
marvt74
Postby AlleyCat » 06 Apr 2018, 13:04
Frank,
Thank you. I confirm it works and the screen goes into a screensaver.
AlleyCat
