Postby hondagx35 » 07 Nov 2015, 14:19
Postby Martin-Fell-C » 07 Nov 2015, 16:15
Hi Frank
Thanks for all the hard work on this
I've seen you said you are uploading the test image >> where do you put these (I may be missing something, but cant see a link to it anywhere)?
Martin-Fell-C
Postby hondagx35 » 07 Nov 2015, 17:52
Hi all,
here is the first test image:
I will post a how to configure in a few minutes.
Postby maurob74 » 07 Nov 2015, 18:13
Thanks for your work!!!!
maurob74
Postby hondagx35 » 07 Nov 2015, 18:57
Postby Perjan » 07 Nov 2015, 20:02
I'm sorry to say but, you're image does not seem to work. It wont connect to the network (wired). And boot on the display hangs on a login screen (don't have a keyboard to check what happens when you login).
Perjan
Postby Sprigo » 07 Nov 2015, 20:16
Sprigo
Postby hondagx35 » 07 Nov 2015, 20:21
Hi all,
sorry my fault.
Will be updated soon.
Postby Perjan » 07 Nov 2015, 20:35
That's what i was afraid off.
Problem solved:
Changed my routers gateway adres and logged in to 192.168.0.14 and set runeaudio to DHCP.
Reset my routers adres to original
Reboot both router and raspberry
Set Local browser to on in runeaudio settings..
Reboot and now its all working
Now lets try it out!!!
Perjan
Postby hondagx35 » 07 Nov 2015, 21:47
Hi Perjan,
thank for the report and your effort to fix the problem.
This happens when you are in a hurry.
Last thing i tested on the image was fixed IP.
I'll change this and upload a new image.
Sorry guys
