Postby morias » 21 Nov 2015, 22:13
I gave this a go last night and it looks very promising however touch is not working on my touch screen. I think I got a bad one as I have tried reseating the touch cable several times with no luck.
Sent from my iPad using Tapatalk
morias
Postby morias » 22 Nov 2015, 04:53
While I wait for a new touch screen could someone let me know if this image dims/turns off the screen during long periods of inactivity.
Sent from my Nexus 4 using Tapatalk
morias
Postby hondagx35 » 22 Nov 2015, 10:51
Postby morias » 22 Nov 2015, 13:16
morias
Postby Perjan » 22 Nov 2015, 20:23
Perjan
Postby morias » 27 Nov 2015, 14:26
morias
Postby guardian » 27 Nov 2015, 17:06
Hello Frank,
I´m using runeaudio for quite a while now, but the possibility to use it as a standalone with the touch diplay really takes it to a higher level! Great job, thank you very much for that!!
So far I just played around a bit. It works really well!
Here something I fell over:
- Sometimes the buttons for stop, play, next... do not work properly. You have to push them several times although the color changes at the first touch, so the touch seems to be recognized.
- The same for the bottom buttons "Library", "Playback" and "Queue"
- Maybe I don´t hit them right. Does the Raspberry 7" touch display has to be calibrated? I didn´t get it to work. Trying to launch xinput_calibrator says "Unable to connect to X server" What am I doing wrong?
- The time elapsed display in the playback view says always 00:00 although the circle around it moves on.
That´s it so far...
Best Regards
Carsten
guardian
Postby hondagx35 » 27 Nov 2015, 17:52
Postby hondagx35 » 27 Nov 2015, 17:54
Hi Carsten,
thank you for the report.
I'm working on a updated image and hope to get all this fixed soon.
Postby morias » 28 Nov 2015, 10:00
morias
