Support: pHAT DAC?
Support: pHAT DAC?
Postby InsecureSpike » 04 Jan 2016, 13:28
hello, I have been wondering if the pHAT DAC from Pimoroni is supported yet, or will it be supported in future?
https://shop.pimoroni.com/products/phat-dac
thanks lots
InsecureSpike
Re: Support: pHAT DAC?
Postby mRqS » 04 Jan 2016, 13:37
On the Pimoroni site, there's a section about setup of the dac.
One line suggests it IS already supported:
"pHAT DAC uses the same hardware as HiFi Berry, so we're borrowing their device-tree overlay for now!"
http://learn.pimoroni.com/tutorial/phat ... ac-install
However, I didn't check it yet (waiting for delivery of my pHat DAC)
Marek
mRqS
Postby InsecureSpike » 06 Jan 2016, 17:14
awesome thank you
InsecureSpike
Postby pistollero » 06 Jan 2016, 20:54
pistollero
Postby ErX » 31 Jan 2016, 20:59
pHat Dac sounds great compared to standard analog audio on the Raspberry Pi. I used the pHat Dac on a Raspberry Pi 1B+ and a 2B.
I cannot compare it with other Dac's, but I'm really happy with this one.
Listened with a great headphone (Sennheiser) and it really sounds good (I like the volume control in RuneAudio by the way).
Greetings,
ErX
ErX
Postby westrock2000 » 04 Apr 2017, 21:16
SSH into the runeaudio player. Go to /etc/boot.txt and uncomment the line that says something about use layer of HiFi Berry.
Then reboot.
You will then be able to select HiFi Berry as a playback source under Settings (I think that one).
Had lots of static with built-in headphone jack, zero with Phat DAC.
westrock2000
